All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #21
Old 11-10-2011, 03:29 AM
wayneh wayneh is offline
Default
So you want a dump load that will only kick in when the system voltage approaches (rises to) the voltage at which the regulator built into the turbine will otherwise take over and start wasting power itself.
Unless I'm mistaken, you can trigger the dumping action on nothing more than system voltage. Charging or not, lights on or not, if the voltage is going up to the range where the turbine takes over, you want to preemptively use your new load.
I think this is a relatively easy task except for the currents involved. It'd be good if somebody with some experience would chime in here.
Just to get you thinking, here's a circuit I just posted for somebody else, showing how excess solar panel power can be shunted to ground if the system voltage rises above a user-settable target. This circuit is fine for 50mA, not 15A.
The voltage is set by the zener diode D2 and tweaked by resistors R2 and R3. It's set up to put ~0.65v at the transistor's base - turning on the shunt to ground - when current starts flowing through the zener, which only happens when the battery voltage gets too high, above the zener voltage plus the drop across the 2 resistors.
Tags
Related Site Pages
Section Title
Worksheet Bipolar junction transistors in active mode
Worksheet DC generator theory
Worksheet Time constant circuits
Worksheet Batteries
Textbook Gas discharge tubes : Thyristors
Textbook Special-purpose diodes : Diodes And Rectifiers
Textbook Practical considerations : Batteries And Power Systems
Similar Threads
Thread Thread Starter Forum Replies Last Post
Quantification of Electrostatic Charge junglelord Off-Topic 14 02-06-2010 07:43 PM
Wind turbine project... 3 phase rectifier-bldc motor controller Cbergerud The Projects Forum 2 12-23-2009 09:54 AM
Is this a good wind turbine/solar charge controller? jwilli The Projects Forum 6 10-05-2009 10:20 PM
Wind generator Voltage controller kronk The Projects Forum 7 01-13-2009 08:22 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
