All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 06-06-2007, 06:30 AM
random_digit random_digit is offline
Default PSPICE Help: Integrating Op-Amp
I'm working on a problem involving designing an ac integrator driven by a 10-V p-p square wave and using Probe to compare waveforms.
I've drawn out the integrator but for some reason it would not create the waveforms for me and said my circuit had errors. Specifically, "Less than 2 connections at node $N_0004"
I looked over my schematic and it looks fine to me, it matches up with what the integrators look like in my textbook. If I had to take a guess to were it would be wrong, it would be either my VPULSE or the non-inverting input of the op-amp.
Could somebody please help me pinpoint my problem, I'm pretty stumped. I've attached my circuit below. Thank you, I appreciate it.
Arthur
  #2
Old 06-06-2007, 11:13 AM
Papabravo's Avatar
Papabravo Papabravo is offline
Default
It is impossible to see where node $N_0004 is located on the schematic. In the netlist generated from the schematic is a node which is connected to only one point. You need to find and eliminate that node. How you do that is PSPICE implementation dependent.
__________________
We never have time to do it right,
But we always have time to do it over.
  #3
Old 06-06-2007, 04:49 PM
Default
Well, I went over it again with a friend who is having the same problem. He found out that it is something with the non-inverting input.
So if I were to follow what you said Papabravo, I am to just delete this? Connect straight to ground?
I'm still stuck -- it won't draw anything out for me. Please help, thank you!
  #4
Old 06-06-2007, 07:37 PM
JoeJester's Avatar
JoeJester JoeJester is online now
Default
What signal are you using as the input? I know you said it was 10 volts pk-pk. Is that 5 volts plus and 5 volts minus? Is that 10 volts plus, 0 volts or the reverse of that?
What is the frequency of your 10 volt pk-pk signal?
__________________
Joe
Navy Electricity and Electronics Training Series (NEETS) - pdf files - http://www.fcctests.com/neets/neets.htm
  #5
Old 06-06-2007, 11:23 PM
Default
I'm using a VPULSE part, going from -5V to 5V.
The problem has 2 parts, one simulation at 1 kHz and the other at 200 Hz. So under the part properties for the VPULSE I put 1/1000 for the PER, but to no avail. I can kind of guess what the waves are going to look like, but I need to have these waveforms present and printed out.
Thank you for all the help so far!
  #6
Old 06-07-2007, 12:26 AM
n9352527 n9352527 is offline
Default
Create a netlist of your schematic and post it here.
  #7
Old 06-07-2007, 01:22 AM
Default
* From [PSPICE NETLIST] section of pspiceev.ini:
.lib "nom.lib"
.INC "chap11.37.net"
**** INCLUDING chap11.37.net ****
* Schematics Netlist *
R_R1 $N_0002 $N_0001 20k
R_Rf $N_0001 $N_0003 50k
C_C $N_0001 $N_0003 .1uF
V_V2 $N_0002 0
+PULSE -5V 5V 1ns 500ps 500ps 50ns .001s
E_U1 $N_0003 0 VALUE {LIMIT(V($N_0004,$N_0001)*1E6,-15V,+15V)}
R_Rc 0 $N_0004 14.2857k
**** RESUMING chap11.37.cir ****
.INC "chap11.37.als"
**** INCLUDING chap11.37.als ****
* Schematics Aliases *
.ALIASES
R_R1 R1(1=$N_0002 2=$N_0001 )
R_Rf Rf(1=$N_0001 2=$N_0003 )
C_C C(1=$N_0001 2=$N_0003 )
V_V2 V2(+=$N_0002 -=0 )
E_U1 U1(OUT=$N_0003 +=$N_0004 -=$N_0001 )
R_Rc Rc(1=0 2=$N_0004 )
.ENDALIASES
.probe
.END
ERROR -- Less than 2 connections at node $N_0004
  #8
Old 06-07-2007, 08:53 AM
Default
Somehow in your netlist U1 is connected only to two nodes $N_0003 and 0 (ground), although your alias seems to understand this and is correct. U1 actually needs to be connected to three nodes, $N_0003, $N_0004 and $N0001.
Check your schematic diagram, make sure all the nodes and wires are really connected and not just very near or on top of each other. Create a new netlist to confirm this.
  #9
Old 06-07-2007, 01:56 PM
JoeJester's Avatar
Default
I have questions about this. Your setting for a pulse width of 50 nS? I believe this exercise calls for a square wave, 50% duty cycle, at the two frequencies of interest.
This could be the reason for your "no output" condition, expecially if your attempting to view it over n milliseconds.
__________________
Joe
  #10
Old 06-08-2007, 04:45 AM
Default
Well, I figured out how to fix my problem with it not showing an output -- since the netlist said that I had less than 2 connections at n_0004 (my non-inverting input), I put a huge resistor in parallel with Rc so it creates a voltage divider, but yet keeps the value of Rc mostly intact. Doing this resulted in an output, which has me estatic even though I'm still trying to fiddle with it to get a nice looking output (damn vpulse).
I think the reason it had me to do this had something to do with the nature of an operating amp and its inherent 'virtual ground' between the inverting and non-inverting inputs.
But oh well, thanks for everything you guys!
Cheers.
Tags
Related Site Pages
Section Title
Worksheet Calculus for electric circuits
Worksheet AC negative feedback opamp circuits
Worksheet Linear computational circuitry
Worksheet Oscilloscope trigger controls
Worksheet Passive integrator and differentiator circuits
Worksheet Mixed-frequency signals
Textbook Computational circuits : Practical Analog Semiconductor Circuits
Textbook Operational amplifier models : Operational Amplifiers
Textbook Ring counters : Shift Registers
Textbook Class B audio amplifier : Analog Integrated Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Single Supply Op Amp Design paulsoulsby The Projects Forum 5 01-31-2013 11:35 PM
Op amp not responding in vehicle Polarity The Projects Forum 5 09-04-2012 12:59 AM
Vox guitar amp problem part 2 efdi The Projects Forum 30 08-17-2012 07:06 AM
pspice 'No recognized product configuration selected.' ad620 op amp moorea21 The Projects Forum 23 09-18-2010 07:26 AM
Experimental design for small sig. amp hobbyist General Electronics Chat 50 07-22-2009 07:42 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
