All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-29-2011, 07:01 PM
PoolMan PoolMan is offline
Default Looking for a function generator circuit using an ECG892.
Hello all! I recently picked up an old ECG892 precision waveform generator chip from my local electronics shop,and i cannot find a datasheet for it. While searching i found an old post where Sgt. Wookie said that it was a clone of a XR-2206. I did find a datasheet for the XR-2206, but i want to make sure the pinouts are the same, at least. Any help would be greatly appreciated!
  #2
Old 10-29-2011, 07:51 PM
iONic's Avatar
iONic iONic is offline
Default
Are you sure the part was supposed to be a function generator? The following datasheet lists an electronic attenuator.
ECG829 Datasheet
__________________
Fight piles of trials with smiles
It riles them to believe
That you perceive
The web they weave
- The Moody Blues
  #3
Old 10-29-2011, 08:06 PM
Default
Yep,its ECG 892 not ECG 829.Thanks!
  #4
Old 10-29-2011, 09:49 PM
Audioguru Audioguru is offline
Banned
Default
ECG doesn't make anything. They buy ordinary ICs from IC manufacturers, print their own part numbers on them then quadruple the price. Gullable people buy them as replacements for the real ones.
  #5
Old 10-30-2011, 02:03 AM
iONic's Avatar
Default
Well the NTE864 and XR-8038 pinout are the same but different than the XR-2206.
Since Sgt. mentioned back in 2007 "Just finished a layout for an ECG892, which was a Philips clone of an XR-2206. Rather decent; 0.01 Hz - 1MHz with 100:1 range in six decades. Yes, it's obsolete too, sadly." Id guess it would be. Unless Sgt. or someone has the ECG892 datasheet kicking around then you will have to wing it. I may have both the XR-2206 and the XR-8038 IC's kicking around if you get desperate.
__________________
That you perceive
The web they weave
- The Moody Blues
  #6
Old 10-30-2011, 03:44 AM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
The ECG892 is indeed the same as an XR-2206.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #7
Old 10-30-2011, 12:27 PM
Banned
Default
Quote:
Originally Posted by iONic View Post
Well the NTE864 and XR-8038 pinout are the same.
Intersil invented the ICL8038. I didn't know that NTE and Exar copied it.
  #8
Old 10-30-2011, 01:52 PM
SgtWookie's Avatar
Expert Member
Default
NTE doesn't copy anything; they just order the parts from OEMs with their own markings on them, then makes an abbreviated datasheet, and waits for the parts to go obsolete.
__________________
General info:
  #9
Old 10-30-2011, 02:16 PM
Default
Thanks everyone!
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
1st step to PIC programing chamara Embedded Systems and Microcontrollers 11 10-22-2011 11:08 PM
VB.net MSComm port USB 4 port relay StealthRT Programmer's Corner 2 10-21-2011 02:20 AM
[Matlab help] How to write and call a user define function? prionkor Programmer's Corner 0 10-11-2009 05:39 PM
Butterworth filter transfer function calculation mentaaal General Electronics Chat 9 03-27-2009 04:54 PM
GUI project in mat lab m75allen Programmer's Corner 6 05-30-2007 11:51 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
