All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 06-04-2007, 03:01 AM
bobby19 bobby19 is offline
Junior Member
Default Simple DC Circuit
Design a DC cct having a 15V battery to provide the following node voltages: +10V, +5V, and -5V with respect to a circuit ground node. Select your resistors such that the max power demand on the battery does not exceed 1mA.
I made a cct with 4 series resistors. 15V source is in series with R1, which is in series with R2, which is in series with R3, which is in series with R4. Since in the question the voltage drops are all equal (5V), I selected 4 equal resistors of 4k. With this design I can node voltages of +7.5, +3.75 and -3.75 with respect to a circuit ground. (I chose the cct ground to be the node connecting R3 and R4)
For the life of me, I dont see a way to get the node voltages specified in the question. Can somebody PLEASE guide me in the right direction??
  #2
Old 06-04-2007, 11:01 AM
Gadget Gadget is offline
Send a message via MSN to Gadget
Default
So far it sounds OK... lets see your circuit diagram....
  #3
Old 06-04-2007, 04:03 PM
Ron H's Avatar
Ron H Ron H is offline
E-book Developer
Default
Here's a big hint: You have too many resistors.
  #4
Old 06-04-2007, 05:21 PM
cumesoftware's Avatar
cumesoftware cumesoftware is offline
Default
Quote:
Actually he hasn't, since he also needs a ground (0V) node between the +5V node and the -5V node. The homework is well done, as far as I can see.
__________________
I love the smell of toasted transistors in the morning.
  #5
Old 06-04-2007, 06:14 PM
Ron H's Avatar
E-book Developer
Default
Quote:
He only needs 3 equal-valued resistors, each greater than 5kohms.
  #6
Old 06-04-2007, 08:41 PM
JoeJester's Avatar
JoeJester JoeJester is offline
Default
It still sounded like an assignment. Three resistors are the minimum, but the OP is suppose to use four.
Let him get back with his drawing.
__________________
Joe
Navy Electricity and Electronics Training Series (NEETS) - pdf files - http://www.fcctests.com/neets/neets.htm
  #7
Old 06-04-2007, 10:00 PM
Ron H's Avatar
E-book Developer
Default
I don't think he said he had to use 4 resistors. I think that was his choice.
  #8
Old 06-05-2007, 01:18 AM
JoeJester's Avatar
Default
I guess IF the OP comes back, he can enlighten us.
__________________
Joe
  #9
Old 06-05-2007, 02:13 AM
Junior Member
Default
Hey,
Because the question is stating 4 node voltages (15V source, +10, +5, -5) and 1 gound, wouldn't you have to use 4 resistors?
I did come up with a design (seen in attachment), however, it was more of a trial error type answer. My question now would be, how would I approach similar problems in the future with a systematic strategy?
  #10
Old 06-05-2007, 03:50 AM
Ron H's Avatar
E-book Developer
Default
Hey,
Notice that R1 does nothing but waste current.
As for design procedure, notice that the difference between your maximum (+10) and minimum (-5) voltages is 15 volts, which is your battery voltage. This means that these two voltages must come from the battery. Since you need 2 other voltages, 3 resistors will be required.
Tags
Related Site Pages
Section Title
Worksheet Series-parallel DC circuits
Worksheet Kirchhoff's Laws
Worksheet Voltage divider circuits
Textbook The R/2 n R DAC : Digital-analog Conversion
Textbook Node voltage method : Dc Network Analysis
Textbook Mesh current method : Dc Network Analysis
Textbook Branch current method : Dc Network Analysis
Textbook Simple parallel circuits : Series And Parallel Circuits
Textbook Simple series circuits : Series And Parallel Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Earth ground for simple DC circuit Lightfire The Projects Forum 43 05-04-2011 07:32 PM
functioning of transistor in simple words PG1995 General Electronics Chat 4 04-21-2011 05:49 PM
Simple but big circuit Challenge to all Chris15 The Projects Forum 13 07-08-2009 09:32 PM
Picking classes - Digital Electronics vs. DC Circuit Analysis sheepsimulator General Electronics Chat 5 06-30-2009 10:22 PM
Robust but simple, Latching Circuit needed! steevg The Projects Forum 2 06-23-2009 10:11 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
