learning basic workings of capacitor
PG1995
Joined Apr 15, 2011
832
Re: energy of charged capacitor
Hi
Q = It, where Q is charge, I is current, and t is time. In case of capacitor I is maximum, I0, at t0 (when the switch is just closed). The current will decrease gradually in exponential fashion. We can find the total charge, Q=It, which flows into the capacitor until the potential difference across it equalizes the potential difference of the battery.
Energy = VI x t. Therefore, we can write, Energy = VQ.
The battery supplied all the charge which went into the capacitor at constant potential, V.
But the formula for power or work done for capacitor is: 1/2 VQ. It's half the work done by battery. Where did the rest of the energy, which is half of the supplied energy, go?
This is what I think. As a capacitor gets charged, the battery finds it hard to push the charge into the capacitor because the capacitor starts resisting the inflow of the charge. Therefore, half of the energy gets lost as heat. This is analogous to the case when air is blown into a balloon. As the balloon gets inflated, it starts resisting the inflow of the air.
Do I make sense? Please let me know. Thanks.
Regards
PG
34,954
The reason the current decreases exponentially is because there is resistance in the circuit. Energy is lost as heat in the resistor.
38,576
All real circuits have some resistance, no matter how small, and that is where 1/2 the energy goes, as noted by MrChips.
So suppose you have a theoretical circuit with an ideal battery, a capacitor, and no resistance. Where does the energy go then? One theory I have heard is that, due to the infinite impulse current spike that would occur when you suddenly connect the battery to the capacitor, a large electromagnetic pulse would be generated, which would radiate away 1/2 the energy. So no matter what you do, only half the energy ends up stored on the capacitor.
