All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-21-2011, 04:02 PM
RRITESH KAKKAR's Avatar
RRITESH KAKKAR RRITESH KAKKAR is offline
Send a message via MSN to RRITESH KAKKAR
Default Working of Digital filters...
I was just thinking how Digital filters work in case of analog we just connected
RC to the signal input to amplifiers, etc
but in case of Digital filter....what happen??
__________________
My work.
My you tube channel... www.youtube.com/user/29riteshkakkar?feature=mhum
  #2
Old 10-21-2011, 09:45 PM
Papabravo's Avatar
Papabravo Papabravo is offline
Default
In an FIR (Finite Impulse Response) filter the present output is a function of the current and previous inputs. If the input goes away then the output goes away. That is the 'F' in FIR.
In an IIR (Infinite Impulse Response) filter the present output is a function of the current and previous inputs AND the previous outputs. If the input goes away the out does not have to go away. That is the first 'I' in IIR.
Finite and Infinite Impusle Response refers to the output over time, NOT the amplitude of the response.
__________________
We never have time to do it right,
But we always have time to do it over.
The Following User Says Thank You to Papabravo For This Useful Post:
RRITESH KAKKAR (10-22-2011)
  #3
Old 10-21-2011, 11:39 PM
crutschow's Avatar
crutschow crutschow is offline
Default
For a digital filter you first convert the analog signal to digital format by sampling the signal at greater than the Nyquist sample-rate for the highest analog frequency using an A/D converter. A digital processor then takes these samples and performs a mathematical function of the values to generate the desired filter response for each sample. If desired the samples from the filter can be then converted back to analog with a D/A converter.
__________________
Zapper
Curmudgeon Elektroniker
The Following User Says Thank You to crutschow For This Useful Post:
  #4
Old 10-22-2011, 03:25 AM
Default
In case of analog low pass filter with connect R and C by using cut of frq. F=1/(2*PI*R*C)....and analyzing by Bode plot.
But this how really work in digital filters??
The input isin form of 010101010 if i want low freq. output of digital signal then what to do??
__________________
My work.
  #5
Old 10-22-2011, 03:22 PM
crutschow's Avatar
Default
The digital filter algorithm is what determines the filter function. A simple low pass function can be performed by generating a running average of the digital values. Thus you would take the difference between the running average and the next sample and add a percentage of the difference to the running average. The cut-off frequency is determined by the digital sample rate and the percent value you add to the running average. It's not as simple a function as the analog circuit.
For more info look at one of these Google references.
__________________
Zapper
RRITESH KAKKAR (10-23-2011)
  #6
Old 10-22-2011, 03:27 PM
Papabravo's Avatar
Default
It works the same way except there is no R and no C. What you do have control of is the sample rate and the coefficients of the impulse response. If you know the coefficients of the impulse response you can compute the output via convolution.
http://www.dspguide.com/
I think Prof. Smith's book is still a free download by chapters in PDF format
__________________
  #7
Old 10-22-2011, 05:25 PM
Default
Guys can you just give an block example for better understanding of digital filters..??
__________________
My work.
  #8
Old 10-22-2011, 08:54 PM
Papabravo's Avatar
Default
Your best bet is to go to the free resources like Steve Smith's DSP book.
Here is another one
http://en.wikipedia.org/wiki/Finite_impulse_response
Boxcar filters have a low-pass characteristic similar to the multi-pole RC filter.
When you do some reading it will lead to more specific questions.
__________________
  #9
Old 10-23-2011, 01:09 PM
Default
I think i am know getting how digital filters work as first we convert analog to Digital then uC/uP do calculation like FFT,etc then output is converted analog.......
But if we talk about convolution theorem it say multiply in freq. domain, vice versa...but what the use and how does it happen in CPU itself??
__________________
My work.
  #10
Old 10-23-2011, 03:06 PM
Papabravo's Avatar
Default
A digital filter is implemented in a CPU by a succession of multiply and accumulate (add) operations. In some processors there is even an instruction that does exactly that operation called "Multiply and Accumulate". A processor can also keep track of previous inputs and previous outputs which may also be used in the filter calculations. Was that what you were looking for?
__________________
RRITESH KAKKAR (10-25-2011)
Tags
Related Site Pages
Section Title
Textbook Delta-Sigma ( ) ADC : Digital-analog Conversion
Similar Threads
Thread Thread Starter Forum Replies Last Post
Digital and Analog TV - Receiver help! Dalaran The Projects Forum 7 01-20-2011 04:16 PM
digital multi meter syed abdullah General Electronics Chat 2 04-14-2010 01:00 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
