All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Electronics Resources
Notices
Electronics Resources Get help with all types of electronics resources, including books, websites, datasheets, technical literature, and software.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-20-2011, 10:59 AM
iMayne's Avatar
iMayne iMayne is offline
Send a message via Skype™ to iMayne
Default Logic Board Corrosion Remover
Hello
Im trying to find ways to spend less on cleaning chemicals. I use Methyl Ethyl Ketone (MEK) to clean liquid spills off logic boards; added I use it with an Ultra Sonic Cleaner machine. Is there a cheaper chemical to get rid of corrosion off PCBs?
Regards
  #2
Old 10-24-2011, 12:52 PM
mcgyvr mcgyvr is offline
Default
It really depends on what the corrosion is..
However I've seen everything from 409 to baking soda/water to rubbing/iso alcohol to MEK. Using a nylon or other soft bristle brush is recommended too.
My opinion is that if the board will/could see spills or is installed in a location that extensive corrosion could happen it should have been conformal coated prior.
  #3
Old 10-24-2011, 01:02 PM
iMayne's Avatar
Default
409 and Baking Sode LOL. I know 99% Alcohol will do but something with Ultra Sonic Cleaners is what I'm after. My cleaner has the heating feature so the fumes rises which I don't like.
  #4
Old 10-24-2011, 05:01 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
A brief dip into muriatic acid (available at pool supply stores for ~$3-$5/gallon) will strip corrosion off of many things. I mean a BRIEF dip; perhaps 30 seconds. The stuff is nasty; don't breath it nor get it on your skin/clothes. I wear rubber gloves and an apron, and use a fan in an open garage to blow the fumes away.
Then flush thoroughly with lots and lots of fresh water to dilute/remove the muriatic acid.
After that, shaking off the water and rinsing in 99% isopropyl alcohol will hasten the drying process. Isopropyl alcohol is hygroscopic (absorbs moisture out of the air) so you have to keep it covered.
Sticking a board into an oven that's been pre-heated to "warm" will help get it to dry faster.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #5
Old 11-07-2011, 05:35 PM
Gdrumm's Avatar
Gdrumm Gdrumm is offline
Default
I recently repaired a Car Battey Charger, and part of the fix was removing the button diodes and cleaning them with a small wire brush (corrosion had a silverish, greyish look).
I also cleaned some wire connectors with the wire brush, they were rusty looking.
I also cleaned some traces on the board with a plastic bristle brush (also silverish, greyish).
What causes that type corrosion, and can it be prevented with a light coating of grease or petrollium jelly?
Thanks,
Gary
  #6
Old 11-07-2011, 11:45 PM
Pipes59 Pipes59 is offline
Default
The cheapest and works great is actually very hot water with a small amount of dish soap. Apply with old tooth brush and get at as much debries as possible. The stiffer the brush the better. Repeat with very hot water less the soap thus rinsing the PC board. I have even just let the hot tap water pour over it while brushing away any residue.
Follow immediately with shake and pat dry. Then hair blower to ensure water is completely evaporated. Most electronics can take this as long as there is not power or battery back-up devices on board. If still in doubt turn oven on lowest setting and place in it for an hour or so.
Always be sure it is completely dry before applying any power.
Most think this will cause rusting down the road. My experience has proved that this is not the case. The water is not on the metals long enough for that process to start. There are also protective sprays you can get to apply after a good cleaning to inhibit corrosion if enviroment is a problem.
Cheers,
  #7
Old 11-08-2011, 02:06 AM
Evil Lurker Evil Lurker is offline
Member
Default
Dow Scrubbing bubbles shower cleaner is the best stuff I have tried. Its a quaternary ammonium compound as the active ingredient so its gentle, pH neutral, and rinses clean. It even removes slight corrosion with a gentle scrubbing using a toothbrush.
There isn't too much difference in MEK's properties next to its chemical cousin, acetone. Its waaaaay to strong and IMO should NEVER be used on a PCB. MEK can eat certain kinds of plastic and is hell on capacitor bungs.
  #8
Old 11-08-2011, 04:11 AM
thatoneguy's Avatar
thatoneguy thatoneguy is offline
Default
If this is something you are repeatedly having to do to the same boards, I'd suggest ordering a Conformal Spray after your cleaning and drying cycle. Chemtronics makes a few, clear and opaque, as well as other companies.
This would be the solution to your corrosion issues, but not the cleaning part.
Tags
Related Site Pages
Section Title
Worksheet CMOS logic gates
Textbook Switch contact design : Switches
Worksheet Basic circuit troubleshooting
Worksheet Soldering
Worksheet Electrical connections
Textbook pH measurement : Electrical Instrumentation Signals
Similar Threads
Thread Thread Starter Forum Replies Last Post
PWM for Treadmill Motor Control Board TD-1600 AresROC The Projects Forum 18 06-13-2013 08:22 PM
Logic Analyzer Help! (Logic Cube) spinnaker General Electronics Chat 4 12-28-2010 11:06 AM
PLC to Control Board roro36 The Projects Forum 0 12-09-2010 10:47 AM
HP1650B logic analyzer vs Open Logic Sniffer quanttrom Electronics Resources 2 12-07-2010 12:57 AM
power supply board gives varying current keenez The Projects Forum 11 06-10-2009 08:30 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
