All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-13-2011, 05:36 PM
cluelessguy cluelessguy is offline
Default Simple Transmitter & Receiver to light up LED
Hi guys,
I was hoping someone could help me with my little project. Im very noob at this. Could someone help me with this? I need a simple transmitter and receiver circuit to light up LEDs. as shown in the diagram, 1 switch lights up 1 LED. I cant figure out how rf signal works, so what i did was i bought a cheap 27Mhz rc car and tried to modify it. Instead of using the motors, i replaced it with LEDs but i cant seem to make the LEDs work all at once.
Someone out there, i really need help with this simple project of mine. And sorry for the bad drawing.
Thanks in advance
  #2
Old 10-14-2011, 12:32 AM
maxthestork maxthestork is offline
Junior Member
Default
Just to check how far you got, you say you
"can't seem to make the LEDs work all at once".
Does this mean you can make them work individually using the remote control?
It is likely that the receiver in the car has functionality that prevents certain combinations of actuation. It would be possible to both drive in reverse and turn right but not to drive forward and backward at the same time or turn left and right at the same time.
  #3
Old 10-14-2011, 04:52 AM
Default
Yes i can make them work individually using the remote control.
The statement you made in your last paragraph is true, i have found out that the car has functionality that prevents certain combinations of actuation.
Somehow the LEDs burn each other out after i press the left then right or vice-verse. The same thing happened to the up and down trigger too.
So is possible in any way that i can modify it more to make it work to the way i desire?
Or do you have a guide on how to build a new board to suite my project?
Thank you very much for replying. Your help is much appreciated.
  #4
Old 10-14-2011, 06:14 AM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
What I read you want is a 4 bit word transmitted and demodulated, with each bit lighting a LED. This pretty basic. You need to frame the question in terms other people can understand and help with, which is what I've done in the first sentence.
Older garage door openers use 10 bit codes, but are very similar.
I suspect you will see some people suggesting PIC (a microcontroller) for a beginner. If they can point to existing plans that can be modified that would be a really good route. Otherwise you will need some second year digital student to lend a hand.
I would normally offer to help, but at the moment I am swamped.
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
  #5
Old 10-14-2011, 03:02 PM
Audioguru Audioguru is offline
Banned
Default
Quote:
Yes, because LEDs burn out if you don't limit the current properly.
  #6
Old 10-14-2011, 04:57 PM
Super Moderator
Default
I missed that part of the thread. I have written a tutorial on LEDs and some special effects for them.
LEDs, 555s, Flashers, and Light Chasers
__________________
General info:
  #7
Old 10-18-2011, 05:01 AM
Default
So is there any other way to build this device in simpler terms?
  #8
Old 10-18-2011, 05:57 AM
Default
Thanks for your response guys.
But what i really need is a transmitter with 4 switches on it and a receiver with 4 LEDs on it. The main purpose of this is that, i need a switch to on a LED, for example, when switch 1 is turned on, LED1 will light up.
I tried to use a rc car because it is similar to how the device function, but instead of motors, i replaced it with LEDs. I was very successful with replacing the 2 motors that controls the up down left right directions with 4 LEDs. The device works perfectly as when i press up/down/left/right, the LEDs work perfectly fine but the problem is i cannot turn all the LEDs at once due to the RC car's configuration which only enables it to either got up+left/up+right/down+left/down+right.
So i was thinking if it is possible to build a new circuit board from scratch which works as i have explained above.
Thank you
  #9
Old 10-18-2011, 06:16 AM
Default
http://jap.hu/electronic/codec.html
I found this website but im not really sure if it suits what i need.
Any advice?
  #10
Old 10-18-2011, 11:03 AM
Default
Have anyone seen an rc car that has headlights but the switch is on the remote controller?
What i am trying to do has the same concept as that.
Tags
Related Site Pages
Section Title
Worksheet Latch circuits
Worksheet Thyristor application circuits
Worksheet Bipolar junction transistors as switches
Worksheet Time constant circuits
Worksheet Series DC circuits
Worksheet Switches
Textbook Networks and busses : Digital Communication
Textbook Simple combination lock : Digital Integrated Circuits
Textbook Special-purpose diodes : Diodes And Rectifiers
Textbook Voltage divider circuits : Divider Circuits And Kirchhoff's Laws
Similar Threads
Thread Thread Starter Forum Replies Last Post
Arduino code Noob Need help Turkish The Projects Forum 8 02-27-2014 02:33 PM
Simple LED Ping Pong ASM shaider6192 The Projects Forum 4 09-07-2011 12:31 PM
How to wire up an simple LED with ever changing voltage princess blacklung The Projects Forum 29 09-09-2009 01:56 AM
LED office-desk lighting system kdaffolder The Projects Forum 1 08-04-2009 07:43 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
