All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-11-2011, 01:15 PM
R!f@@'s Avatar
R!f@@ R!f@@ is offline
Send a message via MSN to R!f@@
Default Looking for an Eagle lbr.
Any body got the SATA connector eagle library.
I cannot find any on the eagle site.
I need this model to make my dual boot HDD PCB.
__________________
R!f@@
Do not get angry and do not be harsh because you will never regret being kind
  #2
Old 10-11-2011, 05:05 PM
Mickster Mickster is offline
Junior Member
Default
Hi R!f@@,
this link may be of some help for you:
http://danstrother.com/2010/12/04/fm...adapter-board/
Scroll down to the Downloads section and there are a couple of .zips you can get.
I haven't checked them out, but there's a chance what you want may be there.
Regards.
EDIT:
OK, downloaded the .zip and opened it. You need the dan-pc.lbr file from the .zip. Add that to your eagle \lbr directory and you'll find three footprints. Depending upon the connector you wish to use, you should be covered.
There's also some other stuff you may find useful in the other libs.
HTH.
The Following User Says Thank You to Mickster For This Useful Post:
R!f@@ (10-11-2011)
  #3
Old 10-11-2011, 07:10 PM
R!f@@'s Avatar
Default
Sweeeeeet..!!
By the way Mickster..that PCIe card shown in the link..what is that for..?
I dunno what it does but it looks really cool to meddle with u know.
__________________
R!f@@
  #4
Old 10-11-2011, 07:41 PM
Junior Member
Default
From what I can gather, it's a Xilinx Spartan-6 FPGA Evaluation Kit -http://www.xilinx.com/products/board...S6-SP605-G.htm - and the user was not initially satisfied with the way the manufacturer chose to route all of the available I/O to a single FMC connector. Hence the break-out-board. What it is capable of though, I have barely the vaguest idea, since I'm still stuck at the "building other people's projects" & the "PIC blinky-light/LCD stage".
I like reading forums and seeing what others are getting up to. Hopefully, I can learn something from what other people are doing. Google has been a good friend for quite a while, so if I can help to find something useful for someone else....
  #5
Old 10-12-2011, 10:36 AM
t06afre's Avatar
t06afre t06afre is offline
Default
This is free tool. That helps you to setup multiple boot options on your system
http://neosmart.net/dl.php?id=1
The Following User Says Thank You to t06afre For This Useful Post:
R!f@@ (10-12-2011)
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
AC Fan Motor Controller; Much Help Needed wescat The Projects Forum 22 02-10-2011 06:30 AM
Need an Eagle lbr file R!f@@ General Electronics Chat 12 09-07-2010 08:29 AM
3.3v dc fan with 1.5v circuit on 1.5v power supply? prdaniels General Electronics Chat 16 09-05-2010 03:27 AM
cpu fan /computer fans??? Mathematics! Computing and Networks 4 11-15-2009 08:39 PM
Learning - project pwm MrWoo The Projects Forum 5 06-19-2007 07:47 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
