All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-03-2011, 09:45 PM
superway superway is offline
Default Diode on relay coil
On the schematic, the diode put across the coil 24vdc is 1N4003. I don't have this diode, but can I subsitute it to 1N4005?
cnv
  #2
Old 10-03-2011, 10:13 PM
#12's Avatar
#12 #12 is offline
Default
Yes
__________________
It's only my opinion, and sometimes I'm wrong.
(I learn something almost every day on this site.)
  #3
Old 10-03-2011, 10:15 PM
ifixit's Avatar
ifixit ifixit is offline
Thumbs up
Yes. The 4005 just has a higher PIV (600V), which you don't need, but will do the job nicely.
__________________
"Learn the rules well, so that you'll know how to break them wisely."
“The quality of an answer is directly proportional to the quality of the question.”
  #4
Old 10-04-2011, 04:23 AM
lageos lageos is offline
Default
This diode suppress cemf of the relay coil.
  #5
Old 10-04-2011, 03:41 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
You may wind up still getting spikes from the coil, as the 1N400x series of diodes don't have a specified turn-on time; so the turn-on time can vary widely from manufacturer to manufacturer, and batch to batch.
If your relay coil is low current (<~80mA) consider using a 1N4148 or 1N914 switching diode. These diodes have extremely fast turn-on and recovery times.
Another technique is to use a small capacitor; 100pF to ~330pF, in parallel with the diode. The small capacitor causes the voltage spike to build much more slowly, which "buys time" for a slow diode to turn on. You don't want to use a cap very much larger than I mentioned above, as if you do, you will have high peak currents through the transistor or MOSFET that is used to power the coil.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #6
Old 10-04-2011, 09:37 PM
ifixit's Avatar
Default
SgtWookie has some good advise, if you are worry about relying on a devices unspecified characteristics.
However, it has been my experience that the 1N400x series of diodes work well for suppressing the back EMF pulse from most relays. Relay coils that have alot of turns on a steel core, means higher intra-winding capacitance and slow field colapse. This slows the EMF rise time down to where the 1N400x series diodes can easlily clamp the voltage to a volt or so.
Regards,
Ifixit
__________________
Tags
Related Site Pages
Section Title
Worksheet Time-delay electromechanical relays
Worksheet Protective relay circuits
Worksheet High-reliability circuits
Worksheet Electromechanical relay logic
Worksheet Basic electromagnetic relays
Textbook CMOS 555 LONG DURATION FLYBACK LED FLASHER : 555 Timer Circuits
Textbook Time-delay relays : Electromechanical Relays
Textbook Relay construction : Electromechanical Relays
Textbook Sensing AC magnetic fields : Ac Circuits
Textbook Inductor commutating circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
12v automotive relay, schmitt trigger, hysteresis, lm358, adjustable 1-4v threshold? elRey General Electronics Chat 4 05-02-2011 05:58 AM
DPDT relay with diode heman90210 Homework Help 3 11-21-2010 06:31 AM
Help needed converting relay circuit to digital dingy The Projects Forum 1 10-26-2010 12:23 AM
Will 27 VAC damage the coil of a 24VAC relay? botanist The Projects Forum 3 05-25-2009 07:06 PM
Unwanted voltage on open relay contacts. NM2008 The Projects Forum 10 05-09-2009 01:07 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
