How do Ifind the most sensitive reed switch?
Status
Not open for further replies.
tikiguy
Joined May 26, 2007
I am working on a project that will use a reed switch. I have been trying to find the most sensitive reed switch on the market, but have been confused.
Basically I am making a device that will open a door using a solenoid, and I want to trigger it from as far away as possible using a neo magnet about the size of 3 nickels stacked together.
I have found some sites that sell reed switches, but couldn't tell what to get for my needs. I will need a switch that is normally open.
Also, is there anything else besides a reed switch that you could suggest that would allow me to have something tiny that could trigger a switch that is not magnetic?
Any help is greatly appreciated.
Thanks,
Tikiguy
beenthere
Joined Apr 20, 2004
15,819
If the idea is to provide a curent path for a solenoid latch, a reed relay is pretty good. Just about anything else will require a power supply and a box holding the circuitry.
You may be able to find specs for sensitivity, but the current handling capacity is most important. Don't know if you can still get the kind that are mercury wetted, but they just lasted forever. Reeds are more sensitive to what part is exposed to the magnetic field - you have to experiment to find the best spot. Some are a bit more sensitive to one pole than the other.
hgmjr
Joined Jan 28, 2005
9,027
Have you considered a Hall-Effect Switch? Unlike the reed switch you will need to power the Hall-Effect device but it may provide you the additional magnetic sensitivity you need.
If you are interested you can google using keyword phrase "hall-effect sensor".
hgmjr (1700)
mrmeval
Joined Jun 30, 2006
833
You could make a magnetic switch. Consider a large piece of metal just balanced enough not to pull a switch closed. Then wave your magnet near it.
You could use a chunk of metal on a pendulum.
Etc
thingmaker3
Joined May 16, 2005
5,083
Reed switch sensitivity is measured in Ampere Turns. The smaller the coil required to activate the reed switch, the lower the AT number. (And the smaller or farther away the permanant magnet needed.) About 10 to 15 AT is as sensitive as the reed switches come.
tikiguy
Joined May 26, 2007
Thanks for the tip about the AT number. That was exactly what I was trying to figure out.
Lincoln
PS - thanks to everyone else for their suggestions as well.
kender
Joined Jan 17, 2007
264
You can make any reed switch more sensitive, if you permanently attach a small magnet to it. The small magnet should be too weak to close the switch by itself, but the 2 magnets (small one and the one that the user has) should be strong enough to close the switch. I've used this method in the past successfully.
BTW, the same approach can be used to make a normally-closed reed switch from a normally open one.
beenthere
Joined Apr 20, 2004
15,819
There is a problem with the above suggestion. The magnetic field constantly present will magnetize the reeds, and they will not open after some time.
I used to work on a disk file that ran the heads in and out with linear motors. The null point in the motor coil was selected with reed relays. They became magnetized and stuck on after a couple of years. If they will do it in intermittent use, a permanent field will just hurry the process.
Every few days, we had to pull one of the reed relay boards and bang it on the floor to open up the stuck contacts.
ludwig
Joined Nov 17, 2008
mcj74
Joined Jan 10, 2007
8
Interesting...
There is a problem with the above suggestion. The magnetic field constantly present will magnetize the reeds, and they will not open after some time... Every few days, we had to pull one of the reed relay boards and bang it on the floor to open up the stuck contacts.
Curious, do you think this behavior has changed with modern reed switches? I was considering trying this, as I need just a little bit more sensitivity
MaxHeadRoom
Joined Jul 18, 2013
30,699
An old thread!
There are compact reed switches and companion magnet made by Hamlin, they are similar to the type used in burglar alarms but generally smaller.
There is also the bare glass discrete reed switches that can be obtained in various sensitivities on the Digikey site.
Max.
Status
