| Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help. |
| View Poll Results: circuit digram on bread board | |||
14 | 100.00% | |
| Voters: 14. You may not vote on this poll | |||
Thread Tools | Display Modes |
#1
plz can u help mee,
i want circuit digram of digital clock circuit on the bread board with this component IC 555 6* IC 7447 5* 7490 1 74192 6* 7SEGAMENT 2* 7414 2* 7408 2* 7402 2* 7476 CAPACITOR 100MF 10* LED R=7.2Kohm, R= 3.6 Ohm thanx |
#2
hi,
are you going to use all those chips you listed to make a digital clock, when you can make a digiclock with just 3 chips.
__________________
THE BIGGEST ROOM IN THE WORLD IS THE ROOM FOR IMPROVEMENT |
#3
Mozikluv's three chip solution is the better one to go for. Most of your TTL chips are out of production (7402, 7414, 7490, 7476) and hard to find. What's the 555 for? The usual source for the timebase is the power transformer. You take off one side with a diode and pad it down through a resistor and zener diode.
__________________
First comes the hardware, then the software. |
#4
thanx for all ,
but where is the circuit digram?????? plz i need it |
| Bookmarks |
| Tags |
| circuit, clock, digital |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| DIGITAL CLOCK with 40W 125VAC Lamps | burbing | The Projects Forum | 12 | 04-18-2008 07:56 PM |
| need a simple digital clock circuit | Major Aspsial Asadullah | The Projects Forum | 8 | 12-11-2007 12:56 PM |
| Digital Clock using DC supply | Anthony Quah | Homework Help | 3 | 12-06-2007 09:08 PM |
| Using a switch to clock digital circuit | colincraig1 | Homework Help | 5 | 10-09-2007 12:29 PM |
| digital clock circuit | nikon | The Projects Forum | 26 | 06-06-2007 03:47 AM |
