All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 09-27-2011, 08:05 PM
MatheusLPS MatheusLPS is offline
Junior Member
Default TL071 do not working with single supply?
So, I am making a little project that I need to compare a 25Khz triangle wave with a 60 Hz sine wave.
Everything is working fine if I use symmetrical power supply for the TL071.
Look:
http://i.imgur.com/TjXAN.jpg
And with single supply:
http://i.imgur.com/wPgR6.jpg
Why is this happening?
bye
  #2
Old 09-27-2011, 08:15 PM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
You need a bias, which is equivalent to a split power supply. When you get too close to one power supply or the other a phenomena called phase inversion happens, where the phase of the signal that is too close to the power supply rail is abruptly inverted. It is common for FET type op amps.
Bill's Index
Creating a Virtual Power Supply Ground
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
  #3
Old 09-27-2011, 08:16 PM
bertus's Avatar
bertus bertus is online now
Super Moderator
Default
In a single supply circuit the signals can not go negative.
You will have to create an offset on the AC signals, in such a way that they can not go negative (about 1/2 Vcc).
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #4
Old 09-27-2011, 08:44 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
The TL07x, TL08x, and LF35x series of opamps cannot "see" within about 3v of the negative supply rail, nor within about 1.5v of the positive rail. You will have strange results if you try to get the inputs or outputs to go closer to the rail than that.
__________________
General info:
  #5
Old 09-28-2011, 12:47 AM
Junior Member
Default
The output do not need to be at the rail voltage.
I will put The output on a mosfet gate driver like the IR2112.
So 5V on the output is very enough for me.
If I understood correct, i can not put AC signals into the comparator with the single suppy?
bye
  #6
Old 09-28-2011, 01:39 AM
SgtWookie's Avatar
Expert Member
Default
Just logic levels won't work very well for those inputs. You'll likely need to exceed 10v for the logic input when high.
Nope.
The TL07x, TL08x series are opamps, not comparators.
If you need a comparator, then use a comparator.
__________________
General info:
  #7
Old 09-28-2011, 02:08 AM
Junior Member
Default
Ok, I understood now....about the comparators....
Can you sugest any one?
One that can drive at least 25khz.. and is easy to find.
I am from brazil and need to order every component from internet.
It is better that the comparator is on stock on the www.farnell.com.br.
bye
  #8
Old 09-28-2011, 03:26 AM
SgtWookie's Avatar
Expert Member
Default
LM311:
http://www.farnellnewark.com.br/ciam...8,4442493.aspx
These are single comparators. They have open-collector outputs.
LM293:
http://www.farnellnewark.com.br/cico...9,4442493.aspx
These are dual comparators with open-collector outputs.
LM339:
http://www.farnellnewark.com.br/cico...3,4442493.aspx
These are quad comparators; they also have open-collector outputs.
The LM293 and LM339 can only sink up to about 6mA until their output saturation voltage starts going up. I'll suggest no more than 5mA. So, if you are using a 12v supply for the digital side of your IR2112, then you will need to calculate 12v / 5mA to get the approximate value of your pull-up resistor; 2.4k Ohms.
__________________
General info:
  #9
Old 09-28-2011, 05:00 AM
Junior Member
Default
I will simulate it here and post the results...
After that, i will mount the circuit on a bread board an test it.
bye
Tags
Related Site Pages
Section Title
Worksheet Design Project: audio media-based signal generator
Worksheet Basic AC-DC power supplies
Worksheet Fundamentals of radio communication
Textbook Standing waves and resonance : Transmission Lines
Worksheet Mixed-frequency signals
Textbook Harmonics in polyphase power systems : Polyphase Ac Circuits
Textbook More on spectrum analysis : Mixed-frequency Ac Signals
Textbook Other waveshapes : Mixed-frequency Ac Signals
Textbook Square wave signals : Mixed-frequency Ac Signals
Textbook Rectifier circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Single Supply, Multiple Load Petrucciowns Homework Help 2 06-18-2009 06:26 AM
High impedance, single supply, absolute differential amplifier gotumal General Electronics Chat 3 06-06-2009 02:22 AM
single 9v supply for + & - 5v regulator childs72 The Projects Forum 7 04-01-2006 11:17 PM
dual polarity from a single supply Earthshaker General Electronics Chat 7 05-19-2005 12:59 PM
-ve voltage from single +ve supply shaun General Electronics Chat 4 02-26-2005 01:35 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
