Perhaps the Factor A and Factor B parameters define control loop tuning parameters relating to heating. Machine size and burner power output will affect the way in which the controller operates, although I would think the algorithms could use closed-loop feedback to make control decisions.1. Factor A (Slope) from 1 to 9 in increments of one (1).
2. Factor B (Heat Loss - Offset) from 1 to 99 in increments of one (1).
HUH!!Perhaps the Factor A and Factor B parameters define control loop tuning parameters relating to heating. Machine size and burner power output will affect the way in which the controller operates, although I would think the algorithms could use closed-loop feedback to make control decisions.
Not at all, I am just not clear at communicating my thoughts!HUH!!
I'm a dummy
You're right, that is odd. For reference, the patent (United States Patent US4827627#Oh ! by the way, what's with the "patent"
The dryer attempts to predict the dryness of the clothes based on the heat required to maintain the set temperature. This Factor A and Factor B appear as a and b in equations on page 9 of the patent document (section DESCRIPTION OF THE PREFERRED EMBODIMENT). Actually despite my ranting about the ridiculousness of many patents, it is nice to have a written description of how your dryer functions!1. Factor A (Slope) from 1 to 9 in increments of one (1).
First of all you should learn assembly,it will help you to understand the architecture of the microcontroller better and in small scale microcontrollers the instruction set is not too large to learn, just couple of days....So debjit it's in C.
Do you use assembly much?
You know I wud luv to know how to code in C.
But even today when I look at a C code I go ???
U knowwhat. I really like you. Drop in to Maldives and gimme a call. I'll show you around and the girls too.It’s like to get married to any girl from Maldives and she will give you permission to get married again... and the next one will give permission for another and this will continue....
2012 1st Jan I will be 23, I think I should get married to any(beautiful ,sexy) girl form Maldives.
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Robert Keim
