All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-17-2007, 07:29 AM
sharath_412 sharath_412 is offline
Junior Member
Default What is quiescent current?
Is it the current consumed by the device when there is no load( regulator)?
Or is the definition based on the component used? for example regulators, Op amps etc.
  #2
Old 05-17-2007, 07:58 AM
awright awright is offline
Member
Default
Your guess is correct. Quiescent current is the current drawn by a circuit when it is not amplifying a signal or driving a load (my definition, not an official definition).
I(q) of a DC-DC converter would be the current it draws when there is no load on the output so it is functioning (i.e., generating the desired output voltage), but is not supplying current to a load.
Same for an IC voltage regulator or an amplifier.
Think of it as the baseline current required to have the device ready to perform its task.
awright
  #3
Old 05-17-2007, 11:06 AM
hgmjr's Avatar
hgmjr hgmjr is offline
Super Moderator
Default
awright has stated the definition quite well.
At the risk of repetition, quiescent current is that amount of current consumed from a power source by a single component or group of components in a circuit when the circuit is in its powered but non-operating state.
hgmjr
  #4
Old 05-17-2007, 01:40 PM
JoeJester's Avatar
JoeJester JoeJester is offline
Default
quiescent
Function: adjective
Etymology: Latin quiescent-, quiescens, present participle of quiescere to become quiet, rest, from quies
1 : marked by inactivity or repose : tranquilly at rest
2 : causing no trouble or symptoms
Definition 1 describes the quiescent condition of a circuit. Typically used in circuits when no drive signal is present.
__________________
Joe
http://www.fcctests.com
Tags
Related Site Pages
Section Title
Worksheet Design Project: intercom system
Worksheet Negative feedback opamp circuits
Worksheet Performance-based assessments for semiconductor circuit competencies
Worksheet Class A BJT amplifiers
Worksheet Regulated power sources
Worksheet Bipolar transistor biasing circuits
Worksheet Bipolar junction transistors in active mode
Worksheet Zener diodes
Textbook Operational amplifier models : Operational Amplifiers
Textbook Biasing techniques : Bipolar Junction Transistors
Similar Threads
Thread Thread Starter Forum Replies Last Post
High Voltage Low Current SoundGuy General Electronics Chat 12 11-05-2009 12:21 PM
Electrostatics - Current!, Convection & Conduction part 1 Nirvana Physics 3 09-11-2007 09:57 PM
fields alphaone Physics 4 12-23-2005 06:03 PM
confused with a npn transistor collector current terrakota Homework Help 1 11-27-2005 11:27 PM
The "real" direction of electric current wbeaty General Electronics Chat 3 07-17-2005 03:23 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
