All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 09-04-2011, 05:48 PM
bluebrakes's Avatar
bluebrakes bluebrakes is offline
Default Fluke 77 Multimeter stopped reading current
my old faithful fluke 77 multimeter has stopped reading DC and AC current.
It still reads Ohms, Volts and continuity, just not current.
I found this guide here...
http://assets.fluke.com/manuals/75_77___omeng0900.pdf
although it doesn't help that the 77 pcb is slightly different to the diagram shown. i.e. I don't have a couple of the components or two fuse holders in mine.
With components being tested with another multimeter still on the fluke 77 pcb, nothing seems to be faulty. I checked the fuseable resistors and i can't seem to find anything faulty.
Has anybody else had this problem or know what component could be at fault?
Thanks.
  #2
Old 09-04-2011, 05:54 PM
bluebrakes's Avatar
Default
photo attached of my fluke 77 board.
  #3
Old 09-04-2011, 07:21 PM
someonesdad someonesdad is offline
Default
The cause for not reading current is usually one or more blown fuses, especially if the other functions work. Since your PCB doesn't have fuse holders, then the fuses must be less obvious components -- maybe you should do a continuity test on all the components.
  #4
Old 09-04-2011, 07:32 PM
t06afre's Avatar
t06afre t06afre is offline
Default
Take a look from page 27 and out in your manual. I think I see one empty fuse holder in the picture. But you should have 2 fuses. And I can not see the the small fuse holder at all
  #5
Old 09-04-2011, 09:59 PM
wmodavis wmodavis is offline
Default
You likely left the red probe in the 10A or 300mA and tried to measure a voltage source that when presented with a near short circuit, dumped enough current into the meter to blow the replaceable fuses.
  #6
Old 09-05-2011, 12:26 AM
praondevou's Avatar
praondevou praondevou is offline
Default
this fluke77 looks different, like in your manual... why? sure your is a 77?
__________________
  #7
Old 09-05-2011, 12:36 AM
praondevou's Avatar
Default
Look here (servicemanual):
http://www.eserviceinfo.com/download.../Fluke_77.html
It says something about R1 and R2 being fusible resistors.... Don't know if it has something to do with it. There seem to exist different series of this model too.
__________________
  #8
Old 09-05-2011, 12:37 AM
hgmjr's Avatar
hgmjr hgmjr is offline
Super Moderator
Default
Make sure you replace the fuse with the proper Fluke fuse.
hgmjr
  #9
Old 09-05-2011, 05:30 AM
Jaguarjoe Jaguarjoe is offline
Default
Aren't those fuses like $10 or so? I popped one of mine and learned to be very, very careful when measuring current. Mistakes are costly.
  #10
Old 09-05-2011, 01:48 PM
R!f@@'s Avatar
R!f@@ R!f@@ is offline
Send a message via MSN to R!f@@
Default
Hmm.!! Where can I find fluke fuses.
I need plenty, cause I use like what comes my way.
__________________
R!f@@
Do not get angry and do not be harsh because you will never regret being kind
Tags
Related Site Pages
Section Title
Worksheet Overcurrent protection
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need Help to solve these three phase balanced load questions Ryza Homework Help 10 06-12-2011 02:46 PM
Help reading data sheet - Max current draw of my PIC? spinnaker Embedded Systems and Microcontrollers 6 10-01-2010 10:54 PM
opamp current direction in e-book swty_todd General Electronics Chat 62 04-02-2009 11:18 PM
reading an analog multimeter gormholler General Electronics Chat 3 01-22-2008 01:58 PM
The "real" direction of electric current wbeaty General Electronics Chat 3 07-17-2005 03:23 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
