| General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos. |
Thread Tools | Display Modes |
#1
I have been trying to understand how to ideally handle the cable shield
on a USB device. (Full Speed USB, in this particular instance.) As seems to be the case with many signal integrity issues, contradictory recommendations abound, each with its own unsupported claims. Even authoritative-sounding sources such as Texas Instruments, Intel, FTDI, and Cypress Semiconductor seem to disagree on the correct way to handle the cable shield on USB devices. Contrary to my initial supposition, the purpose of the USB cable shield is not to protect the USB data lines from outside interference, but rather to prevent the USB device from radiating EMI. Here are some of the options that have been recommended. Note that (2)—series capacitor to pass high frequencies only—seems to directly contradict (3)—series ferrite bead to block high frequencies only. (1) Connect shield directly to signal ground. - “Full speed devices use a shielded cable which requires that the(2) Connect shield to signal ground through a capacitor. (Possibly with high-value parallel resistor approximately 1 Mohm.) - Connect shield to signal ground with 0.01 µF to 0.47 µF capacitor. - Cypress recommends a 1 Mohm resistor in parallel with a 4.7 nF capacitor. - “Tying the shield directly to ground would create a direct path(3) Connect shield to signal ground through a ferrite bead. - “Place a ferrite in series with the cable shield pins near the(4) Do not connect cable shield to ground on the device at all. - As referenced in the AAC thread where to terminate usb cable shield?, Hardware Book says USB devices mustWhether or not the device has a metal chassis, and the handling of chassis ground and signal grounds, (as well as how the USB cable ground is connected to either one) is certainly important as well, but this isn't clearly discussed in most of the writings on USB cable shield grounding. The device I'm developing is a bus-powered device which will likely be in an unshielded plastic enclosure. Thanks in advance for any bits of wisdom on this topic full of contradictory information. I recently posted this question on si-list, and even there I got little in the way of answers. Colin |
#2
Quote:
according to the specifications laid out by the usb-if A metal braid is required to enclose all the wires in the USB 3.0 cable. The braid is to be terminated to the plug metal shells, as close to 360° as possible, to contain EMI.apart from that there is no other requirement the same goes for usb 2.0 it appears that this is a grey area but the sheild should be connected to both sides but not connected to ground in any way. will keep looking for you on the specs and see if i find something |
#3
Quote:
#4
6.8 USB Grounding The shield must be terminated to the connector plug for completed assemblies. The shield and chassis are accepted industry practices and regulatory agency standards for safety and EMI/ESD/RFI.bonded together. The user selected grounding scheme for USB devices, and cables must be consistent with |
| The Following User Says Thank You to ian123 For This Useful Post: | ||
colinb (08-30-2011) | ||
#5
Thanks for posting that snippet. So the shield is connected the the chassis ground, but beyond that, handling of chassis ground is left up to the designer.
That means most any of the suggestions in my prior cited sources are acceptable according to the USB specification; but how this shield/chassis connection is best handled as far as connecting to other grounds in the system is still a point of contention. |
#6
according to the emi standards the connector requires a low impedance to ground
#7
The V BUS and ground in a PC are subject to noise both from on-board sources and also from the switching power supply. Tests have shown that it is necessary to carefully decouple both VBUS and Gnd. This is done with ferrite beads. Separate ferrite beads may be used on each VBUS line to each downstream USB connector. Each ferrite bead on the VCC lines should be rated at 500 ma. Separate ferrites are useful, not only for EMI suppression, but also for their series DC resistance which limits the inrush current during a hot plug event. For a discussion on hot plugging and voltage droop see the USB Voltage Drop and Droop Measurements white paper. Ferrites should also be used on the Gnd lines to USB connectors. If bypassing VCC with ferrite beads still does not provide sufficient attenuation then small (1000 pF) capacitors can be connected on the connector side of VCC to the connector shell through very short traces. If this approach is used care must be taken to insure that the capacitors do not provide a path for ground plane noise to enter via the capacitors. |
#8
But what is ground when two pieces of equipment are involved? For mains-powered equipment, it must be earth ground, but what about portable battery-powered equipment? Obviously in USB there is the GND wire, which the USB Host supplies, so that could be the ground. What if the USB Device is self-powered and does not share ground with the USB Host? I think the answer is the USB requires a common ground from Host to Device and for the special situations where ground must be isolated between these pieces of equipment, special isolation circuitry must be used (optocouplers?).
#9
The shell should be provided with a low impedance connection to signal ground and, in cases where
a metal chassis is present, a means of accepting a metal EMI gasket clip. thats all I have on the subject seems it need to be connected to ground to avoid emi |
#10
ian123,
Thanks for all the info you posted! |
| Tags |
| cable, connection, device, grounding, shield, shielding, signal integrity, usb |
Related Site Pages
| Section | Title | |||
| Video Lecture | Wire and Cable - Basic Components and Technical Notation | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| USB question | CircuitNewbie | Embedded Systems and Microcontrollers | 8 | 01-01-2010 03:18 PM |
| Faulty Electrical causing slow Internet speeds | march09 | Computing and Networks | 7 | 11-12-2009 06:34 AM |
| Grounded benchtop power supply and USB port | yardleydobon | General Electronics Chat | 3 | 05-11-2009 06:14 AM |
| Help with 24 bit serial to usb connection | PhilipH | Embedded Systems and Microcontrollers | 3 | 04-30-2009 07:19 PM |
| USB pin configuration!! | peak99 | The Projects Forum | 3 | 11-20-2008 05:22 PM |
| Thread Tools | |
| Display Modes | |
