All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-29-2011, 09:49 PM
honeymustard909 honeymustard909 is offline
Default TIMER to count for 1 second
Hi there i was wondering if any of you could help me out here . Basically, i need a Timer to count down a time limit which is used to turn off my device after the specified time limit. My pic18f46k20 is running at 1MHz and it is a 16 bit counter . (65536x(1/250KHz) = approx 1 second. I was wondering if this is a correct approach . The period_counter is to increase the second after the timer finish counting from 0-65536 . However to get 1 second , i have to set the period counter to 4000 instead of just 1 . I thought that the timer takes approx 1 second to finish counting.
INTCONbits.TMR0IF = 0; // clear roll-over interrupt flag
T0CON = 0b00000001; // pre scale 1:4
TMR0H = 0x00; // clear timer
TMR0L = 0x00;
T0CONbits.TMR0ON = 1;
void timer (void)
if ( INTCONbits.TMR0IF == 1 )
TMR0H= 0x00;
TMR0L= 0x00;
period_counter++;
if ( period_counter > 4000 ) // 1 second
LATDbits.LATD7 = 1;
period_counter = 0;
counter_second ++;
  #2
Old 08-30-2011, 12:11 AM
Default Timer for 1 second
Why does it takes 4500 to generate a second ?
void main (void)
//Init the output ports
TRISD = 0b01111111; // RD7 as output
//Init oscillator frequency
// OSCCON = 0b00110110; // to set the frequency to 16MHz
// OSCTUNE = 0b01011111;
// Init Timer
// INTCONbits.TMR0IE = 1; //enable interrupt flag
T0CON = 0b00001000; //counts 16 bits no prescaler use internal oscillator
TMR0H = 0x80; // clear timer
TMR0L = 0x00;
T0CONbits.TMR0ON = 1; // start timer
while (1)
timer();
counting();
seconds();
// minutes();
void timer(void)
if (INTCONbits.TMR0IF == 1)
TMR0L = 0xFF;
TMR0H = 0xFF;
period_counter++;
void counting (void)
if ( period_counter > 4500 ) // 1 second (4000)
LATDbits.LATD7 = 1;
period_counter = 0;
counter_second ++;
void seconds (void)
if (counter_second > 1)
LATDbits.LATD7 =0;
counter_second =0;
counter_minute =0;
counter_hour =0;
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need advice - reversing DC motor direction and timer ChrisN The Projects Forum 4 04-22-2011 10:49 PM
Inventory monitoring system..Need help in assembly daredavel Embedded Systems and Microcontrollers 6 02-22-2010 06:18 PM
Wiring a Digital Timer Switch shoe624 General Electronics Chat 2 12-23-2009 01:08 AM
Two stage timer. Need advice. Airasolt The Projects Forum 2 09-10-2009 12:15 PM
count down timer doodsettledown Homework Help 1 10-08-2008 12:21 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
