All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-16-2011, 05:59 PM
surinder surinder is offline
Default thyristor control dc drive
I want to make a three phase analogue thyristor control dc drive. So pl. help if there is any circuit for this drive.
Thanks. surinder
  #2
Old 08-16-2011, 09:15 PM
praondevou's Avatar
praondevou praondevou is offline
Default
Provide as much information as possible please.
What DC control voltage do you have available? Can you use triacs or does it have to be thyristors? What load do you want to switch (power)? What's the 3-phase voltage (country)?
  #3
Old 08-17-2011, 06:35 AM
Dear Sir,
I am located in India and supply voltage is 3 phase 440v here. I want to make a analouge dc drive for 10 hp dc motor and its armature voltage is 440 v dc.So pl.suggest any circuit which we can use for firing of thyristors (used with single quadrent configuration) .
thanks.
surinder
  #4
Old 08-17-2011, 06:55 AM
t_n_k t_n_k is offline
Default
Quote:
Originally Posted by surinder View Post
Dear Sir,
thanks.
surinder
Small power variable speed DC motor drives are readily available off the shelf with all the "bells & whistles" you might need - why do you want to build your own from scratch?
  #5
Old 08-17-2011, 08:40 AM
Kermit2's Avatar
Kermit2 Kermit2 is offline
Default
Doubtful if you could 'make' one as well or as cheaply as you could buy one.
They are complicated and difficult to design.
http://datasheet.elcodis.com/pdf/26/87/268768/fc36m.pdf is just an example and shows the complexity of a such drivers.
__________________
I'm too old.
Tags
Related Site Pages
Section Title
Worksheet Servo motor systems
Worksheet Thyristor application circuits
Textbook AC commutator motors : Ac Motors
Textbook Tesla polyphase induction motors : Ac Motors
Textbook Brushless DC motor : Ac Motors
Textbook Stepper motors : Ac Motors
Textbook Synchronous Motors : Ac Motors
Textbook The TRIAC : Thyristors
Textbook Field-effect-controlled thyristors : Thyristors
Textbook The Silicon-Controlled Rectifier (SCR) : Thyristors
Similar Threads
Thread Thread Starter Forum Replies Last Post
Dc Dc Converter for Solar Charger jaysonphuan88 The Projects Forum 4 03-13-2011 05:42 AM
beta dc amaresh92 Homework Help 4 01-01-2011 05:09 PM
Hard drive crash - geek input needed kdillinger General Electronics Chat 12 02-14-2010 12:40 PM
Control unit to Convert DC 90 volts to constant voltage source of DC 45 Volts. johnraj General Electronics Chat 3 10-05-2008 05:22 PM
Speed control of a single dc drive above as well as below its rated speed using μc mugunthanselvaraj Embedded Systems and Microcontrollers 0 09-22-2008 05:33 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
