All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-13-2011, 02:00 AM
dingy dingy is offline
Default 12vdc servo motor control from 5vdc signal
I have a 12vdc servo motor (locked rotor 1.6 amp) 7.5KΩ pot on shaft.
I would like to build a circuit to control the position of this servo motor with a 5vdc output signal. The 5vdc output has the ability to ramp up its voltage from 0-5 on a 10 point user input curve.
At 0vdc out put from 5v system I would like servo fully retract, as voltage increases to 5vdc output servo motor increases to fully extend.
Looking for somewhat low cost, $20 or less if possible.
I have 5vdc & 12vdc power available.
What would it take to do this?
Gary
  #2
Old 08-13-2011, 05:31 PM
Bernard's Avatar
Bernard Bernard is online now
Default
My take is that servo is a linear push-pull, moror is brushed 12V DC, the 7.5k pot wiper tracks the full length of plunger travel.??
Basic set-up is a window comparator, invertor, & H-bridge. In addition an operational amplifier could be used to give an absolute V for differential input to allow speed control, [ PWM ] & a dead zone to inhibit hunting- would eleminate need for "window" on comparator. Anothet thought: use 2, single V supply OP-Amps, gain between 10 & 100, with inputs paralled but inverted, outputs diode ORd to give an input to a V controlled PWM speed control. Est $ 5.00 in parts.
  #3
Old 08-23-2011, 02:33 AM
Default
1st picture is of new control modules program screen that I want to control servo motor from.
2nd & 3rd are of servo motor. 12vdc motor on servo unit.Resistor is tied to end of output shaft.
The motor RPM causes the control module to output a configurable voltage when a configurable RPM is attained.
5V is maximum possible setting in software.
Gary
  #4
Old 09-01-2011, 04:24 AM
Bernard's Avatar
Default
Is the output shaft allowed to make more than one revolution?
Is there something like a rack & pinion to convert rotary motion to linear motion? " retract & extend"
  #5
Old 09-05-2011, 03:31 AM
Default
The output shaft makes about 270 degree rotation full travel.
The output shaft has a spool on it that retracts a small cable, which then operates another mechanism. The other mechanism is spring loaded to keep cable tight as servo moves back & forth.
Gary
  #6
Old 09-08-2011, 04:48 PM
Bernard's Avatar
Default
The simplest version that I can think of is a comparator & H bridge [ Alegro UDN2962W, 4A, up to 45V, only $1.49 @ The Electronic Goldmine SN: G18502 ]. Additional cktry can be added to limit hunting & control speed.
The Following User Says Thank You to Bernard For This Useful Post:
dingy (09-16-2011)
  #7
Old 09-08-2011, 06:02 PM
xavierpereira xavierpereira is offline
Default
I have Written a code to controll servos but I used Dspic 30f4011 ..
its works fine ..just holla if u need it ... now I working on a different project ..Photovoltaic charge controller ..
The Following User Says Thank You to xavierpereira For This Useful Post:
dingy (09-16-2011)
Tags
Related Site Pages
Section Title
Worksheet Stepper motors
Worksheet Servo motor systems
Worksheet Signal modulation
Worksheet Power conversion circuits
Worksheet Bipolar junction transistors as switches
Worksheet Superposition theorem
Textbook Selsyn (synchro) motors : Ac Motors
Worksheet DC motor control circuits
Textbook Pulse Width Modulation : Dc Motor Drives
Worksheet Potentiometers
Similar Threads
Thread Thread Starter Forum Replies Last Post
implementing clock recovery signal from BPRZ signal f@ryal Embedded Systems and Microcontrollers 9 07-29-2011 06:16 PM
Do guitar pedals draw guitar signal when there is no amp connected at their output? icydash The Projects Forum 25 07-05-2011 11:21 PM
Help with delaying a signal bgosseli The Projects Forum 2 04-25-2011 03:27 AM
Vespa Scooter Turn Signal Help confused_scooter_guy The Projects Forum 3 06-30-2006 11:01 PM
5V and -5V signal menewbie Homework Help 9 03-15-2006 09:59 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
