All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-12-2011, 02:49 PM
crazyengineer's Avatar
crazyengineer crazyengineer is offline
Default Parallel Transistors
I read somewhere that connecting transistors in parallel will increase the current handling capability of the circuit when used as a switch. Can anyone explain why? Also, what happens when you connect them in series?
  #2
Old 08-12-2011, 02:53 PM
RRITESH KAKKAR's Avatar
RRITESH KAKKAR RRITESH KAKKAR is offline
Send a message via MSN to RRITESH KAKKAR
Default
If you connect two battery in parallel the current will increase and voltage will be same ( when both are eg. 12V 12V each)
when they are in series the voltage increase ( eg. 12V +6V = 18V) but current will remain same..!!
The Following User Says Thank You to RRITESH KAKKAR For This Useful Post:
crazyengineer (08-12-2011)
  #3
Old 08-12-2011, 04:04 PM
wmodavis wmodavis is offline
Default
With transistors in parallel each one can conduct up to its allowable current so total current is the sum of capability of the transistors connected in parallel.
Rocket science.
  #4
Old 08-12-2011, 04:30 PM
Adjuster's Avatar
Adjuster Adjuster is offline
Default
In principle, transistors can be used in parallel to increase current handling, or in series to increase voltage handling.
In practice, both these arrangements have their pitfalls, the series connection being really quite hard to realise. It was used for instance in the line deflection circuits of some TV sets at a time when high voltage transistors were hard to manufacture. Unfortunately, the base drive to the series connected transistors required critical adjustment to make them switch at the same instant, sharing the voltage evenly. If this was not achieved, one or other transistor would be overstressed, and in time both would fail.
The connection of transistors in parallel for higher current handling also requires the transistors to be driven on and off at the same time, but transistors may be more tolerant of a momentary over-current. Generally, the difficulty is more a question of current sharing, which may be easier to achieve with MOSFETs than it would be with bipolar transistors.
A MOSFET tends to get less conductive as it heats up, but the reverse is true for a BJT. There is a danger therefore that any one of a set of parallel BJTs may tend to run away with the lion's share of the current: more current = more heat = more current = more heat......BOOM!
  #5
Old 08-12-2011, 04:43 PM
ErnieM's Avatar
ErnieM ErnieM is offline
Default
Quote:
Having worked with switch mode power supplies in the 80's with numerous parallel transistors I can tell you from first hand experience the do NOT go Boom. It sounds more like a sub machine gun:
BAP BAP BAP BAP BAP BAP BAP BAP BAP BAP BAP BAP BAP BAP BAP BAP.
__________________
“Freedom is never more than one generation away from extinction. We didn’t pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same, or one day we will spend our sunset years telling our children and our children’s children what it was once like in the United States where men were free.”
  #6
Old 08-12-2011, 10:41 PM
Jaguarjoe Jaguarjoe is offline
Default
In order for a BJT transistor to work, you must exceed the Vbe of that transistor. Vbe is an indeterminate value somewhere around 0.65v.
When any number of transistors are connected in parallel, the one with the lowest Vbe will begin to conduct first. It will take most of the current causing it to heat more which lowers its Vbe which causes it to conduct more which causes it to heat more blah blah blah. Vbe drops around 1.8mv/deg C. BJT's can be used as a thermometer.
MOSFETs are the opposite, they self regulate because their on resistance increases with temperature, lowering dissipation forcing the rest of the MOSFETs in parallel with it to share a bit more of the load.
  #7
Old 08-14-2011, 01:21 PM
Adjuster's Avatar
Default
Parallel connection of BJTs is possible, but a number of precautions have to be taken if this is going to be successful.
One of the most basic things to do is to de-rate the transistors, i.e. to assume a lower current rating, and so use more in parallel. It can also be helpful to use transistors which have been selected for consistent performance or "matched", but this may be costly and inconvenient. Mounting the transistors close together on a common heat-sink helps to keep their case temperatures as close as possible, but unfortunately internal temperature differences can still occur.
One effective way of improving the current share is to put a low-value resistance in series with each emitter. This is quite commonly done in audio amplifiers. This wastes power, but may be better than seeing the system go up in smoke.
Tags
Related Site Pages
Section Title
Worksheet Conventional transistor overview and special transistors
Textbook The Shockley Diode : Thyristors
Textbook IGBTs : Insulated-gate Field-effect Transistors
Textbook BJT quirks : Bipolar Junction Transistors
Textbook Transistor ratings and packages : Bipolar Junction Transistors
Textbook Current mirrors : Bipolar Junction Transistors
Textbook Biasing techniques : Bipolar Junction Transistors
Textbook Current mirror : Discrete Semiconductor Circuits
Textbook Insulated-gate field-effect transistors (MOSFET) : Solid-state Device Theory
Textbook CMOS gate circuitry : Logic Gates
Similar Threads
Thread Thread Starter Forum Replies Last Post
Mixed Series & Parallel circuit - how to allocate watts ? DrAlloway The Projects Forum 11 04-13-2011 08:56 PM
Making a parallel Port LPT out Transistor interface Cool and fun project CyBerE3 Embedded Systems and Microcontrollers 9 01-13-2011 11:20 PM
Number of CMOS transistors required for... jegues Homework Help 5 10-01-2010 12:49 AM
BJT's - NPN Power Transistors Carel General Electronics Chat 12 06-21-2009 04:45 PM
PWM Parallel Power Transistors damianhealey The Projects Forum 85 01-22-2009 06:54 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
