This is a major revision of this project here, and that is why I decided to open a new thread. Basically it is a similar amplifier, having essentially the same characteristics. However some measures were taken to prevent potential problems, making it more stable. The amplifier is now entirely AC coupled, and thus it cuts any DC bias on the input. The output uses boucherot cells and coils to stabilize the LM3875s against HF oscillations that might occur.
List of components:
C1/2/7/8 – 10mF electrolytic capacitor (50V);
C3/5/9/11 – 100µF electrolytic capacitor (50V);
C4/6/10/12/16/20 – 100nF polyester capacitor (63V);
C13/17 – 1µF polyester capacitor (63V);
C15/19 – 220pF ceramic capacitor (63V);
C15/19 – 22µF non-polarized electrolytic capacitor (6,3V);
D1-4 – 6A05 rectifier diode;
F1 – 2A slow-blow fuse;
F2/3 - 6,3A slow-blow fuse;
HS1/2 – 1,2°C/W passive heatsink;
IC1/2 – LM3875 audio power amplifier (LM3875TF);
J1 – IEC C14 connector;
J2/3 – RCA female connector;
JW – 26AWG stranded wire;
L1/2 - Air core coil, 16 turns with 6mm dia. of 22 AWG wire;
LP – 230V~ resistored neon bulb;
R1 – 10KR double gang potenciometer (10% tol., 1/8W);
R2/9 – 4,7KR carbon resistor (5% tol., 1/8W);
R3/10 – 47KR carbon resistor (5% tol., 1/8W);
R4/6/11/13 – 1KR carbon resistor (5% tol., 1/8W);
R5/12 – 33KR carbon resistor (5% tol., 1/8W);
R7/14 – 2.7R carbon resistor (5% tol., 2W);
R8/15 – 10R carbon resistor (5% tol., 1/2W);
S – DPST switch;
T – Toroidal transformer 230V~ pri. 2x18V~ sec. 225VA.
Electrical parameters:
- Va min = 207V RMS
- Va max = 253V RMS
- Ia (Va = 230V RMS, Z = 4Ohm) = 991.9mA RMS
- Ia (Va = 230V RMS, Z = 8Ohm) = 686.7mA RMS
- P (Va = 230V RMS, Z = 4Ohm) = 228.1W
- P (Va = 230V RMS, Z = 8Ohm) = 157.9W
Amplification characteristics (each channel):
- Input impedance: 3,197-10KOhm
- Input sensitivity: 500mV RMS
- Gain: 30,63dB (34V/V)
- Frequency response (-3dB): 7.234-120000Hz
- Output power (Z = 4Ohm): 45W
- Output power (Z = 8Ohm): 29W
Thanks to the guys here in AAC and those from diyAudio for all the help and advise while doing this revision. It wouldn't be possible without them.
List of components:
S – DPST switch;
- Va min = 207V RMS
- Va max = 253V RMS
