All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-02-2011, 08:07 PM
scol scol is offline
Default Moving Coil Meter + Shunt
I'm doing some course lab work and need to write up a report.
This is because of my laziness throughout the year and I missed a lab anyway. I'm a little hazy on the subject of moving coil meters and shunts/multipliers - I've been learning electronics for years and have a good understanding I just wanted to ask for some help to clear it up as this just had be a bit confused.
I have a MCM with an F.S.D. of 100μA and resistance of 1KΩ.
I have to A, modify the following circuits and calculate the component values to allow for voltages of 0 - 1V and 0 - 5V so I can read the voltages across V1, V2, V3, V1 + V2, V2 + V3, V1 + V2 + V3. The first is using the multiplier, i.e. resister in series with the MCM.
I worked out 8050Ω for the resistor to go in before the MCM (0 - 1V).
Then 48050Ω for 0 - 5V.
[Series]
>-- 5V PSU --- R1(470Ω) --- R2(150Ω) --- R3(330Ω) -->
The second circuit involves using a shunt which is the one I got really stuck with I have pages of formulas and calculations but can't get a consistent answer. Remeber this time it's parallel.
[Parallel]
Any help would be great or even just simplified explanations as I'm unsure on what to do?
  #2
Old 08-03-2011, 02:16 AM
t_n_k t_n_k is offline
Default
Shunts are placed across MCM's to allow the user to measure higher currents than the meter's full scale deflection allows. They are not used for voltage measurements.
Suppose you want to transform your 100uA MCM to a 1A full scale current meter.
At 100uA and 1kΩ the meter requires 100mV to give full scale indication.
So your parallel shunt carries close enough to 1A (less only 100uA) which will produce 100mV and will therefore require a resistance of 100 milli-ohm, since Rshunt=100mV/1A=100 mΩ.
One used to buy meter shunts denoted as say 100A 50mV, 50A 50mV etc - meaning these would respectively produce 50mV with 100A [R=500uΩ] and 50mV with 50A [R=1mΩ] of current flowing. These would be readily compatible for range extension with a MCM of 50mV FSD.
For setting a smaller full scale current reading you may need to be more careful with the calculations. Say you want to expand the MCM range from 100uA to 1mA. In that case the shunt carries 900uA (1mA-100uA) for 100mV full scale. So the shunt resistance needs to be Rshunt=100mV/900uA=111.11Ω
  #3
Old 08-03-2011, 05:46 AM
JoeJester's Avatar
JoeJester JoeJester is offline
Default
Maybe this diagram will help you ...
__________________
Joe
http://www.fcctests.com
Tags
Related Site Pages
Section Title
Textbook Ammeter design : Dc Metering Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Electrodynamometers & Meter Coil Rewinding ac4aq General Electronics Chat 1 11-04-2010 10:00 AM
Variable meter shunt concept - could this work? Dyslexicbloke General Electronics Chat 15 09-15-2010 12:51 PM
buffer for moving coil meter alanjackson Homework Help 3 06-03-2010 06:21 PM
Simple Ignition Coil Circuit Driver Sirisian The Projects Forum 4 05-15-2010 03:22 PM
moving coil meter - please help debbie Homework Help 5 01-18-2007 12:59 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
