| General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos. |
Thread Tools | Display Modes |
#1
I have a need to install a power relay in a circut with a ext. fuse box at the end. I have several Bosch relays of the correct amp rating but i'm confused with what to do with the switch lead on the 4 post relay, same with the 5 post. what swithch (Type) would I connect it to?-JSP2242
#2
Explain more about what you're trying to do.
#3
Pin numbers are not standardized among relay manufacturers. 5 pin tells us nothing.
Bosch relays don't have a 4 or 5 pin. Google Bosch relays under images tb, you find the images below http://www.classictruckshop.com/club...osch/relay.jpg Typical relay: http://www.bcae1.com/images/jpegs/relaycov.jpg 5 and 6 in the images of the typical relay perform the same function as 30 on the Bosch relay. It's the common contact. The typical relay is a DPDT switch. Pin 5 normally connects to pin 1, NC, normally closed. When the coil is energized, that contact opens and common connects to pin 3, the NO, normally open contact. So: on this typical relay, A and B are the coil. 5 and 6 are the common contacts for the 2 switches. 1 and 2 are normally closed, they are connected to common when the relay is relaxed. 3 and 4 are normally open, connected the common contact when the relay is energized. You could just read the tutorial: http://www.bcae1.com/relays.htm |
| Tags |
| connect, relays |
Related Site Pages
| Section | Title | |||
| Worksheet | Time-delay electromechanical relays | |||
| Worksheet | Protective relay circuits | |||
| Worksheet | Electromechanical relay logic | |||
| Worksheet | Thyristor application circuits | |||
| Worksheet | AC motor control circuits | |||
| Worksheet | DC generator theory | |||
| Worksheet | Basic electromagnetic relays | |||
| Worksheet | Arc flash and arc blast | |||
| Worksheet | Electrical connections | |||
| Textbook | Relay construction : Electromechanical Relays | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| relays help | jav_ | Homework Help | 3 | 03-09-2007 04:52 AM |
| 4 pin car relays | Cossiedave | General Electronics Chat | 5 | 03-02-2007 05:52 PM |
| Replacing normal relays with self lock relays | Hali | General Electronics Chat | 4 | 02-28-2007 08:10 AM |
| how to connect IR led to 555... | TNT | General Electronics Chat | 7 | 05-29-2005 02:45 PM |
| Protective Relays | maurice_vandoorne | General Electronics Chat | 4 | 05-09-2005 05:48 AM |
| Thread Tools | |
| Display Modes | |
