All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 07-02-2011, 04:49 PM
Clarence Donath Clarence Donath is offline
Default AC noise isolation from 555 circuit
I'm using a 110VAC industrial signal bell, like a fire alarm bell, controlled by a 555 timing circuit of my own design. The bell is isolated from the timer through two relays. The first relay switches 12VDC to the second relay, which switches 110VAC to the bell.
The problem is the timer circuit is re-triggered indefinitely by EMF or other type of noise from the bell.
It could be line noise passing through the relays, or EMF released inside the aluminum enclosure. The bell is physically located 6 feet from the enclosure.
I've tried other AC loads, such as a high power fan that do not cause this. The AC bell is just very aggressive.
I would appreciated any suggestions to isolate the EMF from the timer circuit.
Could an AC line filter be used at the entry point of the bell receptacle to the enclosure? I'm not familiar with AC line filters, and I don't want to degrade the performance of the bell.
  #2
Old 07-02-2011, 10:47 PM
Jaguarjoe Jaguarjoe is offline
Default
Break this down in steps. Make the 555 work well with a minimal load, like an LED.
Next, make it work with the first low voltage relay, then with both relays and no bell. If all of this works OK, then focus on the bell.
Your bell probably has a set of interrupter contacts inside of it that open and close as fast as the bell clangs. They are probably sparking a lot radiating noise everywhere. A capacitor across the contacts may fix this.
You could eliminate both relays and the noisy bell contacts by adding another 555 an opto coupler and a triac. Use both 555's (or 0ne 556) as a toneburst generator. That feeds the opto which isolates you as well as triggering the triac.
You can simplify the toneburst generator considerably by using a cheap 8 pin microcontroller in lieu of the 555's. This would also provide a simple way to control the bell's ringing frequency and its on/off time.
  #3
Old 07-03-2011, 12:39 AM
someonesdad someonesdad is offline
Default
You could also consider getting rid of the bell and getting an electronic noisemaker that doesn't create the nasty noise. I agree with Jaguarjoe that it's probably the root of your troubles.
If not, also remember to put some good bypassing caps on your power supply and right next to the 555 and other consumers of digital signals to keep the noise down.
Tags
Related Site Pages
Section Title
Worksheet Time-delay electromechanical relays
Worksheet Electromechanical relay logic
Worksheet Basic AC-DC power supplies
Worksheet Electrical noise and interference
Worksheet Step-up, step-down, and isolation transformers
Textbook Power supply circuits -- INCOMPLETE : Practical Analog Semiconductor Circuits
Textbook Introduction : Mixed-frequency Ac Signals
Textbook LED sequencer : Digital Integrated Circuits
Textbook Sound cancellation : Ac Circuits
Textbook Diode switching circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Which 555 timer trigger circuit is better? iakobos The Projects Forum 6 07-24-2011 01:32 PM
DC circuit or AC circuit? Jas9 General Electronics Chat 3 11-13-2010 01:05 AM
555 timer delay circuit ak47_hardik General Electronics Chat 2 11-09-2010 02:27 PM
Help/advice with 555 timer circuit Addo The Projects Forum 4 06-23-2008 10:06 PM
Time Lapse Camera 555 Timer Circuit Question la quokka The Projects Forum 8 03-22-2008 02:30 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
