All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 06-20-2011, 03:07 PM
@m@ @m@ is offline
Junior Member
Default XR2206 function generator circuit connecting with Instruementation amplifier
hello to everyone...!
I have made function generator circuit using XR2206 and it works perfectly with varying frequencies of 20Hz-20KHz.. But the the problem is that when i connect this function generator output to the input of AD620 (pin 3) having Rg=100 then there is no output at the pin 6 of AD620 whereas when i connected the same fucntion generator output to my low pass butterworth filter (Fc = 25 Hz) then its working as well as showing excellent frequency response.. I am just stuck here ... what's the problem with AD620...? ( my AD620 circuit is working fine when input is given by lab Function generators)
Thank u...
  #2
Old 06-20-2011, 03:46 PM
beenthere's Avatar
beenthere beenthere is offline
Default
We need to see a complete schematic to be able to see what might be wrong.
__________________
First comes the hardware, then the software.
  #3
Old 06-20-2011, 06:07 PM
Audioguru Audioguru is offline
Banned
Default
The XR2206 uses a single-polarity supply so its output is at a positive voltage.
The AD620 probably has a dual-polarity supply so its DC gain is amplifying the DC output of the XR2206 which causes the output of the AD620 to be slammed as high as it can go.
Simply add a coupling capacitor between them to block the DC but pass the AC. The input of the AD620 will need a resistor to 0V.
  #4
Old 06-20-2011, 06:17 PM
t06afre's Avatar
t06afre t06afre is offline
Default
The 620 is a Low Power Low Drift, Low Power Instrumentation Amp with Set Gains of 1 to 10000. I do not know what you try to create. It may be that it is ok. But are you sure the Instrumentation Amp is the correct thing to use in your application
  #5
Old 06-20-2011, 07:19 PM
@m@ @m@ is offline
Junior Member
Default
Actually I am making circuit for EEG .. the need of function generator is just for checking my circuitry through sine wave input and to check out my filter responses that either they works f9 or not and the first stage of my circuit is AD620 (I.A) ,if AD620 will not show output for this function generator then how i will be able to check my whole circuit... It was not so hard to make function generator .. Ryte
  #6
Old 06-20-2011, 10:02 PM
#12's Avatar
#12 #12 is offline
Default
You have been answered. The answer is: AC couple the output of the oscillator.
  #7
Old 06-21-2011, 12:10 AM
mozikluv mozikluv is offline
Default Xe2206
isolation indeed
__________________
THE BIGGEST ROOM IN THE WORLD IS THE ROOM FOR IMPROVEMENT
  #8
Old 06-21-2011, 08:03 AM
@m@ @m@ is offline
Junior Member
Default
oka thanks for the help ...!
i will try this & then will inform u ppl , that it is working or not...
thank u..
  #9
Old 06-22-2011, 11:51 AM
@m@ @m@ is offline
Junior Member
Default
thanks every1 its working
Tags
Related Site Pages
Section Title
Worksheet Calculus for electric circuits
Worksheet Basic logic gate troubleshooting
Worksheet Linear computational circuitry
Worksheet Summer and subtractor opamp circuits
Worksheet Negative feedback opamp circuits
Worksheet Multi-stage transistor amplifiers
Worksheet JFET amplifiers
Worksheet BJT amplifier troubleshooting
Worksheet Series-parallel combination AC circuits
Textbook Voltage-to-current signal conversion : Operational Amplifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
need help in connecting Lock in amplifier matsci General Electronics Chat 18 12-30-2013 06:57 AM
Connecting headphones to amplifier speaker output? Mckayman The Projects Forum 2 10-13-2010 06:49 AM
Help regarding audio amplifier.. sarang2502 General Electronics Chat 16 04-27-2010 10:16 PM
Connecting the bulk of a PMOS.. (CMOS complex function) wiz0r Homework Help 1 04-22-2010 11:19 PM
What is the function of Inverting amplifier? angeline_happyoo General Electronics Chat 5 09-13-2007 08:40 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
