How to make the textscan command skip the line with texts
talhak
Joined May 30, 2011
hi,
anybody know how the textscan can be used to skip the text line in file and carry on reading the data in a sequence. I have to read a file with numeric data but the text appears randomly in the file. i have to skip and read the next line.
But one thing i have observed that once the textscan reads the text file i keeps on returning empty array.
here the code:
fname = input('Enter Data File Name:','s');
fid=fopen(fname,'r');
r=zeros(300,8);
for j=1:300
C = textscan(fid, '%d', 8);
m = cell2mat(C);
r1=m';
r(j,:)=r1;
j=j+1;
if j==300
break;
end;
end
plot(r(2:300,1));
So, the code reads the data up to 300 samples, but the text appears 2 or 3 times for two rows. Once the textscan reads the text it gives error and returns empty array. The data is like that:
-12 -42 40 -75 -70 -110 -153 -140
-4 -55 -18 -144 -130 -183 -234 -207
17 -22 -41 -161 -131 -190 -221 -179
-62 -92 16 -89 -71 -96 -129 -109
-38 -64 89 -17 -31 -35 -95 -73
-80 -71 43 -68 -65 -94 -147 -134
-45 -59 -11 -124 -122 -189 -216 -180
-62 -69 -42 -157 -128 -195 -228 -186
-65 -81 53 -42 -32 -45 -88 -49
-79 -84 117 19 19 -3 -53 -35
-39 -52 44 -54 -46 -76 -121 -105
-22 -32 1 -119 -118 -166 -194 -161
HEART_RATE 54
LEAD_OFF_STATUS 1,1,1,1,1,1,1,1,1,0,0,0,0,0,0,0
-4 -12 -38 -148 -114 -172 -199 -174
30,824
Funny thing, I have the exact same problem.
As far as I know there is no quick fix to this problem.
You will have to read each line in as text and parse each line.
I hope this helps.
