All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-31-2011, 02:42 PM
PG1995's Avatar
PG1995 PG1995 is offline
Default supermesh and supernode
Mesh analysis and supermesh:
In mesh analysis we apply KVL. Voltage sources offer no problem and the same is true of current source when it exists ONLY in one mesh. As a side note, a mesh is a loop which does not contain any other loop within itself. The problem arises when the current source (independent or dependent) exists between two meshes. So, then to solve the circuit a supermesh is created by excluding the current source and any elements connected in series with it.
Nodal analysis and supernode:
In nodal analysis we use KCL. Therefore, the number of current sources and their placement does not offer problem and the same is true when the voltage source is connected between the reference node (at 0V) and the nonreference node; we simply set the voltage at the nonreference node equal to the voltage of the voltage source. The problem arises when the voltage source (independent or dependent) is connected between two two nonreference nodes. Then, to solve the circuit a supernode is formed by enclosing the voltage source between the two nonreference nodes and any element connected in parallel with it.
Please correct or modify the text above if you think I have missed on something important, so that I don't run into trouble while doing the problems. Thanks
  #2
Old 06-03-2011, 05:57 AM
PG1995's Avatar
Default
Would someone please comment on my post above? Thanks.
  #3
Old 06-03-2011, 06:24 AM
jegues's Avatar
jegues jegues is offline
Default
I don't like how you are calling some of these situations "problems"! There is certainly no problem with supermeshes and supernodes!
In mesh analysis we apply KVL followed by Ohms Law.
In nodal analysis we apply KCL followed by Ohms Law.
It's good to read through the theory, I but find you learn the most by working through examples.
Good luck!
  #4
Old 06-03-2011, 08:30 AM
PG1995's Avatar
Default
Thanks a lot, jegues.
  #5
Old 06-03-2011, 09:37 AM
bertus's Avatar
bertus bertus is online now
Super Moderator
Default
The eBook on DC on top of the page has the following pages on KVL and KCL:
Kirchhoff's Voltage Law (KVL)
Kirchhoff's Current Law (KCL)
Those will give you enough information on the subjects.
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #6
Old 06-03-2011, 02:36 PM
PG1995's Avatar
Default
bertus, thanks a lot.
Regards
PG
Tags
Related Site Pages
Section Title
Worksheet Negative feedback opamp circuits
Worksheet DC mesh current analysis
Worksheet DC branch current analysis
Textbook Three-phase Y and Delta configurations : Polyphase Ac Circuits
Worksheet Kirchhoff's Laws
Textbook Quirks : Using The spice Circuit Simulation Program
Textbook Node voltage method : Dc Network Analysis
Textbook Mesh current method : Dc Network Analysis
Textbook Branch current method : Dc Network Analysis
Textbook Kirchhoff's Current Law (KCL) : Divider Circuits And Kirchhoff's Laws
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
