can the city shut off your sewer service?
strantor
Joined Oct 3, 2010
6,875
So last night I was taking a shower and my toilet started making a bubbling noise. I poked my head out to see, and when I looked back in the shower, turds were gurgling up through the drain. I promptly got out and shut off the shower. the bathtub was backed up, about 3" of water standing in it, not going down at all, as if completely blocked. when the washing machine on the other side of the house went into rinse/spin cycle, suds bubbled up into the shower. I checked my bathroom on the other side of the house, same story. it was as if the main drain of my house had been 100% blocked. I could not reach a plumber so I went to sleep. about 30 min later I was awakened by a loud sucking sound and went to check it out; as fast as the blockage had occurred, it went away and all my backed up toilets and showers went dry. It was as if the city had disconnected my sewer service and then restored it. anybody else experienced this before?
Joined Nov 30, 2010
18,224
In Florida, it's called a collapsed pipe. About 50 years ago they used tar paper to make sewer pipes...Maybe the name of it was Orangeburg.
You're going to need a plumber or a shovel if the pipe collapsed. For now, pray that somebody flushed a diaper and it cleared up by itself.
strantor
Joined Oct 3, 2010
6,875
wow, tar paper, really? seems a bit insufficient. My neighborhood went up in the late '70s in houston TX; I wonder if I've got tar paper pipes.
Georacer
Joined Nov 25, 2009
5,182
In many towns we don't have a sewer system. Each house or building has a burried tank that collects all of the used/flushed water. A special tanker truck comes, usually once a month, and empties your trunk, not for free, of course.
You can tell when your neighbour empties his tank just by breathing - Refreshing.
Kermit2
Joined Feb 5, 2010
4,159
You have a blockage. Our house had the same exact problem a couple of years ago. Main line blockage was cleared by the plumbers.
Cast iron, or ceramic clay pipes were in use in the 70's. We had the cast iron. Houses built in Houston in that period will all be the same due to code requirements
#12
Joined Nov 30, 2010
18,224
I'm betting on Kermit. Local building codes and when the house was built are the key to this.
The tar paper pipes were outlawed a long time ago, but not long enough to save me from digging the trench. Lucky you, a blockage is much easier to fix than rotten tar paper pipes. I hope your luck holds and it's a diaper, not tree roots.
someonesdad
Joined Jul 7, 2009
1,583
If it is a blockage, sometimes you can fix it yourself. I had our kitchen sink back up on us, but the other pipes in the house continued to work. I went to the local rental place and rented a powered snake. I got pretty lucky because I rented the short one (50 feet if IIRC) and took out the plumbing under the sink to get access, then ran the snake into the hole. I found and fixed the blockage when there was just 1 or 2 feet left in the line. The snake was powered by an electric drill and it quickly cleared the blockage. That's the only blocked line we've had in about 25 years in this house, knock on wood.
Later on, I measured under the house and figured out exactly where the blockage was because I had measured the distance on the snake.
You can probably read up a bit on the web about the technique first, but it's not terribly hard to do. I sure hope it's not a bad pipe, as plumbers and digging to replace things runs into the $1000's of dollars automatically.
#12
Joined Nov 30, 2010
18,224
My neighbor paid $3400 to have her pipe replaced about 6 months ago, and it was only 25 feet!
I did mine, myself. About $300 (including $50 for a helper). Mine was more like 50 feet. I used Schedule 40 PVC. No more collapsed tar paper and no chance of tree roots sneaking into that kind of glue connection. No worries, mate!
retched
Joined Dec 5, 2009
5,207
If the blockage is located AFTER the in-yard cleanout, it is the citys responsibility. If it is on the house side, it is yours.
Proof is usually done by getting(renting) a pipe cam.
Sunbelt rents them. It shows the length of camera snake wire that has run, until it hits the clog.
For my home, it was 38 feet. That was 8 feet past the clean out. Free repair.
A neighbor two doors down did NOT heed my advice and had the SAME problem. $3800
Here is what you want to rent:
http://www.abceqrental.com/products.php?id=718&location=&top=Products&cat=77,152
SunbeltRental.com website is down until tomorrow, but I rented mine through them for $60 for a halfday rental.
Check home depot, etc. for other companies that rent them.
It is SUPER easy to do, you can often stick them right into the toilet.
If you have a more rigid one, you may have to pull the toilet.. simple task.
Shut off tank supply, flush toilet. Remove 2 bolts that mount toilet to floor (flange actually)
Pull straight up and set somewhere.
Shove scope in hole, watch monitor, dodge turds like a video game ;)
Remember to RECORD this.
Most cams have a standard VHS VCR built into the monitor.(included in rental)
While your at it, buy a new wax ring from home depot.
Set the wax ring over the old wax ring, slide the toilet back over the two bolts, and sit on the toilet. Get up and put the nuts on the bolts and tighten a littler more than hand tight.
If it is other peoples poop floating up, you may have a main clogged.
Ask your neighbors if they have noticed any plumbing oddities. (Nicer than asking if they shower with turds ;) )
strantor
Joined Oct 3, 2010
6,875
Thanks a bunch for all the tips. I was slow to respond because I didn't get any email alerts that I had replies. I will get the pipe cam if the blockage occurs again, and if needed, move on to the digging and replacing.
Wendy
Joined Mar 24, 2008
23,797
This is because it is a public health issue. Unprocessed sewage in the wrong place can cause disease or plague.
loosewire
Joined Apr 25, 2008
1,686
A question,If gray water was pumped down to the thermal
portion of the earth center or that zone would the steam
allow certain harmful things to survive. Do you think the
water would be safe to drink.Our water today contains
harmful things they have no test for.The gray water is being
pumped below the aquafers now,there is question about
contamination already.You would be the last to know.
They say bottled water is just tap water being bottled.
Gray water is treated sewage water mixed with every thing
flushed down the drain,chemical and all.Wonder where all these
strange diseases come from and your immune system.
Think about seeds and spores and things being dormant.
loosewire
Joined Apr 25, 2008
1,686
I know this stuff before the Times,I watch them drill years ago.
They lied,they said they doing a test hole..It had all the equipment
that a fresh water well has and monitored.
debe
Joined Sep 21, 2010
1,419
Im not so sure about grey water, my daughter works in a hospital working with cancer patients on chemo treatment. The treatment must be pretty toxic as nurses wear protective gear & after a patient has been to the toilet it is so toxic it must be flushed twice. One wonders where this toxic waste finishes up & what hapens in recyling the the water if it malfunctions?
