All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-25-2011, 10:42 AM
abuster abuster is offline
Default Just another mosfet AC switch thread
Hi there!
I've used days searching and reading forums for finding a good solution to switch AC with mosfets in totem, source-to-source. TRIAC is not an option, as I want to switch of in other times than phase-over(PWM, reverse phase dimmer, etc). SSR are overkill, and to expensive.
Like many others, I stranded upon the problem with the floating source, and found solutions with a photovoltaic optocoupler. But, the photovoltaic optocouplers available from my supplier are pretty expensive.
So, I made a circuit with LTspice, using a rectifier and a optocoupler with transistor output. That way, I can feed the mosfet gate with a positive/negative pulse.
The cheap optocouplers usally have about 10+us on/off time, so that will be a limitation with high frequency switching(for example 100khz PWM).
This seems to work, but I wondered if any of you had real life experince with this type of setup?
The application will be fed with 12VAC. The load will be max 50-100W resistive. The models used are random, and I will adjust that to my application(Rds on, max current, max gate-source/drain-source voltage, type of optocoupler, etc).
  #2
Old 05-25-2011, 10:44 AM
Default
And, the controlling pulse will be 5V from a micro controller.
  #3
Old 05-25-2011, 12:00 PM
JDT JDT is offline
Default
The simple way to do this is by connecting two N-channel mosfets in series as shown.
This works because fets are actually bi-directional. A positive voltage on the gate (with respect to the source) switches the channel to a low resistance regardless of the direction of current in the channel. So if you choose a fet with a sufficiently low on resistance, the body diode on the reversed fet will not conduct. This can make a very low voltage drop AC switch.
I have used this circuit to switch 24VAC 250W halogen lamps with high efficiency.
Be careful though: Make sure that the voltage on the gate is either zero or sufficient to switch full-on. Even during power up. Or your fet will be quickly destroyed. I know from experience!
Another complication: Your drive circuit will probably have to be isolated from your micro-controller. As the sources are probably at some unknown AC voltage. A small floating power supply or DC-DC converter might have to be used. Unless your complete micro-controller circuit is attached to the sources.
  #4
Old 05-25-2011, 12:22 PM
Default
Thanks for sharing your experience.
As you say, the complication lays in ground level, and floating mosfet source.
The way I planned to do it, was to set one of the AC phases as common ground(the circuit will be totally isolated from touching), and have +/- DC floating from that level. That way, the sources at the mosfets will float to a minus voltage when the body diode of the upper mosfet is forwarded. As you state, this will potentially burn the mosfets, if the gate is not at a lower voltage.
A problem with this, might be that gate-source voltage gets to high. When not conduction, we have potentially -17V(minus body-diode drop) amplitude plus the +/-17 voltage.
Do you have any schematics how you made it work with isolated DC on the micro-controller?
  #5
Old 05-25-2011, 12:52 PM
Default
Actually, as my simulation shows, the sources are pulled against ground level when load is above the mosfet totem and gate rising from -16V. Maybe the optocouplers rise-time is enough to get a smooth transistion, and not blow the mosfets because of the +-20V gate-source voltage limitation.
  #6
Old 05-25-2011, 03:22 PM
JDT JDT is offline
Default
There are many ways of doing this but consider that
  • The MOSFET must always be fully OFF or fully ON
  • The gate has a high capacitance, so to switch the transistor fast the driver must be able to sink and source high currents.
  • There needs to be an under-voltage lockout so that the transistor can never be partially on when the supply voltage is low.
I suggest using a mosfet driver IC. It's all on the chip. An example driver circuit is attached. I have used an opto-coupler and a small DC-DC converter. Gate current is only needed when switching so only a small supply current is needed. It is possible to get the supply current from the AC supply itself using diodes and resistors.
  #7
Old 05-26-2011, 08:05 AM
Default
Thanks. One step further to prototype
Tags
Related Site Pages
Section Title
Worksheet CMOS logic gates
Worksheet TTL logic gates
Worksheet Junction field-effect transistors
Textbook Diode switching circuits : Diodes And Rectifiers
Textbook Insulated-gate field-effect transistors (MOSFET) : Solid-state Device Theory
Textbook Junction field-effect transistors : Solid-state Device Theory
Textbook Logic signal voltage levels : Logic Gates
Textbook Special-output gates : Logic Gates
Textbook CMOS gate circuitry : Logic Gates
Textbook The NOT gate : Logic Gates
Similar Threads
Thread Thread Starter Forum Replies Last Post
High side mosfet as a switch umer27 The Projects Forum 13 12-22-2012 09:32 AM
MOSFET Switch Schematic tracecom General Electronics Chat 4 05-06-2010 07:14 PM
Question regarding a 12v DPDT switch loydt General Electronics Chat 10 03-03-2009 10:25 PM
building long range RF controlled AC switch janelson The Projects Forum 3 12-21-2008 06:12 PM
voltage tests and thermostats ac circuits bonkers General Electronics Chat 4 12-14-2008 12:41 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
