All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-23-2011, 05:16 PM
FroMan FroMan is offline
Default Monostable 1 microsecond LED pulsing circuit
Good day all,
I am in the process of trying to get a monostable LED pulsing circuit to work as part of my masters dissertation in mechanical engineering (that's right, mechanical, so I am a bit out of my depth here). Thus far I have managed to produce the required pulse duration down to a mere 500 nanoseconds however I am not getting anywhere enough illumination from the LED. All I require is around 1 microsecond of the brightest possible illumination, no limits!
The circuit is to be used in conjunction with some high speed pressure transducers to capture shock waves reflecting off various object in a shock tube. The system to produce the TTL signal to trigger the circuit is already working.
Without going into too much detail, the light is emitted from the LED, passes through some colour masks, bounces off some cleverly placed mirrors and is captured with a digital SLR.
The optics just in front of the camera allows all the deflected light rays (due to the change in density of the air in the shockwave region) to pass and blocks all the un-deflected rays.
You can see my video in the youtube attachments using the LED system in constant mode.
http://www.youtube.com/watch?v=9WxqU...layer_embedded
and
http://www.youtube.com/watch?v=L9Rm-...layer_embedded
I cant see how to attach images to posts so Ive uploaded the circuit diagram to youtube:
http://www.youtube.com/watch?v=BU5OJ...layer_embedded
IC2 is a 5v regulator, IC1 is the 74121 monostable vibrator CMOS chip, Q1 is the IRL520 MOSFET and LED2 is the high power LED. I have been using some Cree MCE 180lm multicolour LED's to get as broad and even visible spectrum as possible. I require all visible light wavelengths and not just a monochromatic light due to the color requirements of the optics system. R4 is a 1 ohm resistor to monitor current draw and S1 is just a switch to turn the LED on for optical alignment purposes. I need to fiddle with this side of the circuit still.
I have a feeling the MOSFET is not turning on fully (gate-source voltage not high enough??) and thus the LED cannot draw enough current?? How to check this??
Any comments would be hugely appreciated on anything related to this circuit
  #2
Old 05-23-2011, 11:22 PM
KJ6EAD's Avatar
KJ6EAD KJ6EAD is offline
Default
An RGB LED may not be the best choice if you want white light since it has gaps in it's spectral band between the three peaks. A white LED does a better job filling in the gaps.
For such a short burst, you should be driving the LED to it's peak current rating instead of limiting to it's continuous rating. Of course you must limit using the continuous rating for your alignment function.
  #3
Old 05-24-2011, 02:40 AM
CDRIVE's Avatar
CDRIVE CDRIVE is offline
Default
Quote:
Just click "Manage Attachments" below the "Submit Reply" button, in the additional options panel.
__________________
__________________________________________________ ___________________________
Disclaimer: Any information that I post is intended for educational purposes only. No warranty or liability is expressed or implied. Note: Working with household line voltages (Mains) can be dangerous. Proceed at your own risk!
  #4
Old 05-24-2011, 05:55 AM
nickelflipper nickelflipper is offline
Default
Putting a scope on the gate of the IRL520 should provide some answers. Consider providing 10V, and up to 300-500ma, to the gate using a 2N7000 as a switch.
  #5
Old 05-24-2011, 08:03 AM
Default
Quote:
How would this differ from powering the FET directly as both the FET and the 2N7000 have similar gate threshold voltages?
  #6
Old 05-24-2011, 04:32 PM
Default
16ma ttl gate drive may not overcome the gate capacitance in 1us. So checking the mosfet gate with a scope would put that angle to rest one way or the other.
  #7
Old 05-25-2011, 01:44 AM
Audioguru Audioguru is offline
Banned
Default
Human vision sees light pulses normally when the duration of the pulses is 30ms or more.
But when the duration of the pulses is less than 30ms then the light appears to be dimmed.
  #8
Old 05-25-2011, 01:57 AM
Banned
Default
Don't look at the threshold voltage that is when the Mosfet is barely turned on (it is almost turned off) with a current of only 0.25mA.
Instead, look at the GS voltage when the on-resistance is guaranteed to be a stated low resistance.
Tags
Related Site Pages
Section Title
Worksheet Design Project: Logic probe
Similar Threads
Thread Thread Starter Forum Replies Last Post
LED lamps getting hot MingJae Homework Help 20 02-25-2010 01:54 PM
Newbie need help with LED semiconductor strobe circuit customsportbike The Projects Forum 6 02-12-2010 01:44 AM
LED office-desk lighting system kdaffolder The Projects Forum 1 08-04-2009 07:43 AM
Math Help with a Simple LED circuit fish4fun The Projects Forum 3 03-03-2009 04:04 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
