All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-22-2011, 05:46 PM
peter_morley's Avatar
peter_morley peter_morley is offline
Default Sine wave with 555 timer and RLC circuit
A 555 timer creates a high low pulse. What I want to do is create a sine wave from the output of the 555 timer. I have looked online and it involves a bit of calculus so I wanted to see if it was worth my time. I realize the RLC circuit connected to the output of the 555 needs to be over-damped to create my sine waveform. I'm not doing any transmitting for radio waves at this point I'm just trying to learn how create oscillator circuits. Its a useful tool to have and most of all cool!
__________________
"I think it's much more interesting to live not knowing than to have answers which might be wrong."
Richard P. Feynman
The faster you move, the slower time passes, the longer you live.
  #2
Old 05-22-2011, 06:02 PM
Kingsparks Kingsparks is offline
Default Sine wave from 555
I don't know about useful, that depends on you. As far as cool, well, I think so but then I like almost anything having to do with the 555. It won't be a true sine wave but you can get it pretty close. It is real easy to breadboard then "play with," "try it, you'll like it."
  #3
Old 05-22-2011, 06:24 PM
DickCappels DickCappels is offline
Default
It can be pretty simple. Just set up the 555 to make a square wave (approx 50% duty cycle) at the desired frequency. Then make a RC low pass filter using a 1K resistor and a capacitor calculated to give you a corner frequency at about 1/2 the frequency of the square wave. After that, place another RC low pass filter with the same corner frequency, but using a 5.1k resistor (so you don't load down the first filter section too badly), then follow it by a third stage with the same corner frequency, this time using a 27k resistor. That will get you a pretty good looking sine wave. You can lower the corner frequency or add more stages to get better suppression of the higher order harmonics.
  #4
Old 05-22-2011, 10:36 PM
Default Filter
Would the filter look this this?...attached schematic and graph. A to D are assigned as larger amplitude to smaller amplitude of waveforms.
__________________
Richard P. Feynman
  #5
Old 05-22-2011, 11:08 PM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
Pretty much. LC works much better, but RC gets the job done. One problem though, it still won't be a pure sine wave, just very close.
You could also use the input to the 555 (where it is a triangle wave) to remove one layer of RC circuits.
You can also use integrators to make a better approximation, instead of a sawtooth you would have a true triangle waveform for example.
My Cookbook
http://forum.allaboutcircuits.com/sh...ad.php?t=10936
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
  #6
Old 05-23-2011, 02:37 AM
Default
Bill_Marsden - Ok so no matter what the output will not be a perfect sine wave. Can you show me how to make a sine wave the LC way with the 555 timer...and is it possible to make a sine wave with just an inductor, capacitor and resistor without the 555 timer? So two requests here.
__________________
Richard P. Feynman
  #7
Old 05-23-2011, 03:19 AM
Super Moderator
Default
There are lots of ways to make high quality sine waves. Pick a frequency.
Actually, with enough filtering, you can make a very good sine wave, one for all practical purposes is pure.
The old LC resonance formula is your friend, F=1/(6.28*(LC)^0.5). I'd LaTeXt except I don't have a lot of time for this post.
Just build a LC low pass followed by a LC by a LC band pass, not necessarily in that order. LC circuits are much more precision than RC versions.
Sine Wave Oscillators A PDF abstract by TI
__________________
General info:
  #8
Old 05-24-2011, 12:07 PM
THE_RB's Avatar
THE_RB THE_RB is offline
Default
The big question is; do you want to change the frequency?
It's much easier to generate (and filter) sine at a fixed frequency, if you want to be able to vary the sine frequency that changes everything!
__________________
Roman Black - PICs and electronics. Author of BTc PIC-sound encoder, Shift1-LCD project, the TalkBotBrain talking PIC controller, LiniStepper open-source microstepping motor driver, the Black Regulator 2-transistor SMPS, and probably some other stuff; www.RomanBlack.com
  #9
Old 05-24-2011, 06:38 PM
Super Moderator
Default
Which is why it is better to use something like a Wien Bridge Oscillator or one of the other directives.
http://en.wikipedia.org/wiki/Wien_bridge
__________________
General info:
  #10
Old 05-25-2011, 03:22 AM
Ron H's Avatar
Ron H Ron H is offline
E-book Developer
Default
Quote:
It needs to be underdamped.
Tags
Related Site Pages
Section Title
Worksheet Phase-locked loops
Worksheet Oscillator circuits
Worksheet Passive integrator and differentiator circuits
Worksheet Passive filter circuits
Worksheet Mixed-frequency signals
Textbook What is a filter? : Filters
Textbook More on spectrum analysis : Mixed-frequency Ac Signals
Textbook Other waveshapes : Mixed-frequency Ac Signals
Textbook Square wave signals : Mixed-frequency Ac Signals
Textbook 555 audio oscillator : Analog Integrated Circuits
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
