Which in this picture is the 0.1µF and 1µF radial?
Lightfire
Joined Oct 5, 2010
690
OK. I purchased this capacitors somewhere and I am confusing which is the 0.1µF and 1µF radial. So which?
Take a look at my attachment?
Thanks!!!
magnet18
Joined Dec 22, 2010
1,227
Neither of those capacitors is of the radial design.
1uF capacitors usually look like tiny little metal cans wrapped in plastic (usually black & grey)
Lightfire
Joined Oct 5, 2010
690
capacitors: 0.1µF ×4, 1µF radial beased on the parts required for my project
What does this means? They should be both radial? I mean this means, I need radial for 0.1uF and 1uF? or one of them are axial? Pls help!!!
thanks
Lightfire
Joined Oct 5, 2010
690
Anyway, the orange capacitors I have purhcased has this description
F
104
___
KCK
And the blue has (logo like A) then 1P2
Wendy
Joined Mar 24, 2008
23,415
No sign of a package yet?
Where are you getting your parts? You have something close by?
Radial just means the leads are coming out of the bottom instead of the sides, which is axial. Resistors are generally axial, capacitors both.
I have 1µF in every case style, including ceramic disk (large), tantalum (small, very small), electrolytic, and other.
I believe the markings on the blue cap were 1nK63, in which case it is what I said it was, a 0.001µF cap.
bertus
Joined Apr 5, 2008
22,270
For the question Radial versus Axial, I have take a picture from some electrolitic capacitors.
The one with the leads on BOTH sides is called AXIAL.(the wires are on the axe of the component.)
The one with the leads on ONE side is called RADIAL.
For tha values and codings of capacitors take a look at this page:
http://www.sentex.ca/~mec1995/gadgets/caps/caps.html
Bertus
Audioguru
Joined Dec 20, 2007
11,248
I have many European EPCOS blue 1nF/5%/63V caps that look exactly like that. They are metalized plastic film type. The leads have 0.2" spacing.
Wendy
Joined Mar 24, 2008
23,415
Pretty much what I said in post #10. However, the markings in this case suggest otherwise (assuming I'm reading them correctly).
Lightfire
Joined Oct 5, 2010
690
Actually yes. It was "1nK63" but in the receipt, it is not 0.001μF. Indeed, a "Ceramic 1μF". Help?
