All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-18-2011, 06:33 AM
BruceBruce BruceBruce is offline
Junior Member
Default 4 bit up/down counter project using D flip flops
I'm trying to design and test a 4-bit version of an Up/Down Counter using D Flip flops. I need it to be Up'/Down = 0 then the circuit should behave as an up counter. If Up'/Down = 1 then the circuit should behave as a down counter. I also need to create an input waveform file to test the procedure in a "full count" up and down.
Oh i need to design this in Quartus II software. It can be a schematic or VHDL code.
Thanks for the help hopefully.
  #2
Old 05-18-2011, 02:22 PM
Georacer's Avatar
Georacer Georacer is offline
Super Moderator
Default
Oh, aren't you in luck. Take a look here, lower half of the page:
http://www.allaboutcircuits.com/vol_4/chpt_11/3.html
Come back with your questions.
__________________
I am a prisoner of high standards and low social skills
____________________________________
I wish I was the best at what I would do, and what I would do wouldn't be pretty.
  #3
Old 05-19-2011, 02:14 AM
Junior Member
Default
Thats an up/down counter using a jk flips flops. i need it with d flip flops. I can write the code for a Four bit counter with d flip flops but i dont know how to make it an up and down counter.
  #4
Old 05-19-2011, 06:31 AM
Junior Member
Default
would i design it similarly to that with the d flip flops instead of the jk flip flops and have the OR gates going into the D input instead of the J and K inputs. How would the first D input go? (pictures help lol im good with those)
  #5
Old 05-20-2011, 04:30 AM
Junior Member
Default
this is what i got so far:
Uploaded with ImageShack.us
well i dont know what to plug into the d input of the first FLip flop. In the diagram for the JK flip flop 4 bit counter it had Vdd as the first input to j and k. What is Vdd and how do i incorporate that into my diagram. Also the "up/down" is that just a regular input labeled up/down? i know the q0-q3 are all the outputs but where do i end that last "NOT Q" to?
Hopefully you guys can answer this and help me fix the drawing. I got tell friday at midnight to turn it in for a grade. Ill owe whoever helps me out big time. If you would like to email me than please send it to <SNIP>. Thank you.
Last edited by bertus; 05-20-2011 at 04:55 AM. Reason: removed email address to protect you from spam
  #6
Old 05-20-2011, 05:28 PM
Georacer's Avatar
Super Moderator
Default
I haven't been on a computer in the last 48 hours, hence the late reply.
Let's think about the difference between a JK FF and a D FF and how we can convert the second into the first, to serve our purpose.
In the schematic I posted you, you will notice that a signal coming from an OR gate drives both J and K inputs of a JK FF, flipping its state each time it has a value of '1'. The D FF doesn't have that functionality inherently. We must build some circuitry to produce it.
Remember: On the presence of a '1', we want the FF to switch state. What if we take the Q' output of the FF and AND it through a gate along with the '1' signal? Do you see how that would work?
You can find another proposition in this thread:
http://forum.allaboutcircuits.com/sh...ad.php?t=45624
__________________
  #7
Old 05-20-2011, 08:23 PM
Junior Member
Default
Also in the quartus program how do i get "Q NOT"? there isnt a pin for it on the D Flip Flop icon. do i just run a Not gate off the Q? i attached a pic of it
  #8
Old 05-20-2011, 08:28 PM
Junior Member
Default
heres the new design. let me know what you think. I gotta turn this in by midnight tonight(california time PST) GeoRacer.
  #9
Old 05-20-2011, 10:58 PM
Georacer's Avatar
Super Moderator
Default
That not quite right. Since you seem to not handle a new schematic well, why don't you take the AAC schematic as it is and replace the JK FF, with a module that will be comprised of a D FF, and an AND gate.
You have the J/K common input of you module which should switch state when the signal from the OR gate on the schematic is '1'.
In other words, you need to find a way to give the D FF input a Q when the OR output is '0', and Q' when the OR output is '1'.
That can be accomplished with a 2-to-1 MUX.
Can you figure out how?
The first FF will have its hypothetical OR input raised to '1' permanently (or just connected to its Q' for economy).
__________________
  #10
Old 05-20-2011, 11:33 PM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
What are these? I haven't run into those logic symbols before,
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
Tags
Related Site Pages
Section Title
Video Lecture JK Flip-Flop - Digital
Worksheet Counters
Worksheet Flip-flop circuits
Video Lecture Counters - Digital
Textbook Ring counters : Shift Registers
Textbook Serial-in/serial-out shift register : Shift Registers
Textbook Finite State Machines : Sequential Circuits Counters
Textbook Asynchronous counters : Sequential Circuits Counters
Textbook Synchronous counters : Sequential Circuits Counters
Textbook The J-K flip-flop : Multivibrators
Similar Threads
Thread Thread Starter Forum Replies Last Post
Up/Down 3-Bit Counter Using 2 D f/fs and 1 J/K f/f Lurid Homework Help 0 11-24-2010 06:35 PM
FSM using D-Type Flip Flops ra1ph Homework Help 2 11-24-2010 08:11 AM
up/down counter afiremain General Electronics Chat 3 11-10-2008 11:40 PM
Designing a 3-bit counter with D flip flops Mearyk81 Homework Help 4 05-31-2008 10:44 PM
3-digit up/down counter with computer-interface dionaide The Projects Forum 3 08-27-2007 02:04 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
