All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-30-2007, 04:53 PM
Talmadge Talmadge is offline
Default 480 volt single phase lighting
I am new to this forum, I hope that I am posting my question in the right spot.
Help! please, I have a situation where all of the lighting in our new (not newly constructed) facillity does not work in our parking lot and I have never encountered the type of lighting fixture on our poles.
I am the maintenance electrician, Our service is 480 3 phase, 277 phase to ground and 480 pahse to phase. the transformers (ballasts) in this particuler light fixture has a common, a 120 volt lead, a 208 volt lead, a 240 volt lead, a 277 volt lead and a 480 volt lead. I have three phases and a neutral available in each light standard (pole). The curent configuration is the common is connected to the neutral as it should be and the 480 volt lead is connected to one leg (phase) of 480 which would be 277 volts. All of the parking ot lighting was installed in 1988 the fixtures are very old and we are going to rebuild them. but I need to know what type of balasts should I order. I have never heard of 480 single phase, that is what these light were hooked up as originally. I guess my question is could someone explain 480 single phase to me and how is it different from 277?
Any help would be apreciated.
Talmadge
  #2
Old 04-01-2007, 06:09 PM
Sparkyfrm Sparkyfrm is offline
Default
Single phase 480 is 277 volt. To get 480 you need two phase at any given time to give you 480 volts. In (3) three phase systems, they alt. between the (3) different phase . That why with a motor, if you switch two of the phase make up points then the motor will change direction of rotation.
You will need a 277 volt ballast for the type of lighting you are using; being it be Metal halide lamp, high-pressure Mercury Lamp,or high-pressure sodium .
You might just have bad cap. or ign. not the ballist it self.
  #3
Old 12-21-2008, 02:56 AM
cavie cavie is offline
Default
480 volt single wire 2 is used in highway lighting. It is 480 volts to ground. Had a hard time getting my head wraped around it.
Tags
Related Site Pages
Section Title
Worksheet Delta and Wye 3-phase circuits
Worksheet Electromechanical relay logic
Worksheet Polyphase power systems
Worksheet Step-up, step-down, and isolation transformers
Textbook Harmonics in polyphase power systems : Polyphase Ac Circuits
Textbook Three-phase power systems : Polyphase Ac Circuits
Textbook Single-phase power systems : Polyphase Ac Circuits
Textbook Automotive alternator : Ac Circuits
Textbook Special-purpose diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help, what is single phase Leo General Electronics Chat 13 01-17-2009 12:23 PM
277 volt lighting / transformer Erin G. Off-Topic 6 03-14-2008 09:58 AM
calculation delta and star motor power? straw Homework Help 10 05-15-2007 03:47 PM
Power Engineering Help (Star-Delta) mksa Homework Help 2 05-09-2006 05:41 AM
SPDT as transfer switch for single phase? notlag General Electronics Chat 1 04-09-2005 04:54 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
