All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #11
Old 05-06-2011, 11:47 AM
mawais15 mawais15 is offline
Default
i was planning to use an automobile induction generator with a belt and pulley system to give enough rpm to the generator. one of my friend suggested me to use a DC-DC convertor to regulate the voltage output.
if i would use battery, then there is no problem at all but i don't want to use battery because of some issues. Thats why i am looking for an alternative to get a fairly regulated voltage from turbine to be directly fed in the invertor.
  #12
Old 05-06-2011, 11:50 AM
Default
Quote:
Originally Posted by russpatterson View Post
What voltage range do you expect from your wind powered generator?
I guess it'll be 0-24 V. Not sure coz i've not tested the thing so far
  #13
Old 05-06-2011, 11:51 AM
Default
Quote:
Originally Posted by #12 View Post
A battery is the way I'd do it. A battery converts however much energy you are producing into chemical energy at a fairly steady voltage. That is much easier to regulate that trying to build something that can cope with the huge variations you will get from the turbine.
battery iz a solution but its not included in my project :-s
  #14
Old 05-06-2011, 05:29 PM
wayneh wayneh is offline
Default
Quote:
Originally Posted by mawais15 View Post
i was planning to use an automobile induction generator ...
Is that just an alternator? You may be better off to stay in the AC domain and never convert to intermediate DC. For one thing, you'll avoid the inevitable power loss in diode rectification. There are ways to convert one AC voltage to another. Obviously a transformer works for a single input voltage, and there is a thing called a Variac for manually adjusting the ratio. You need something fancier.
  #15
Old 05-07-2011, 06:43 AM
Default
you're right but there is no other way i have. talking about the variable transformer, it would be difficult for one to automatically adjust it setting accordingly with input voltage.
  #16
Old 05-07-2011, 04:50 PM
Default
Difficult, yes. You're asking for the holy grail of wind power - a device that accepts any input signal and converts it to 120v, 60 Hz. That's not simple, and I'm not aware of any general solution.
  #17
Old 05-08-2011, 06:58 AM
Default
i've started to figure out that its outa reach
Tags
Related Site Pages
Section Title
Worksheet AC generator theory
Textbook Tesla polyphase induction motors : Ac Motors
Textbook Synchronous Motors : Ac Motors
Textbook Practical considerations : Transformers
Textbook Voltage regulation : Transformers
Textbook Special transformers and applications : Transformers
Worksheet Sources of electricity
Textbook What is alternating current (AC)? : Basic Ac Theory
Textbook Automotive alternator : Ac Circuits
Textbook Special-purpose diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
help with choosing DC control AC output relay vijaybala85 General Electronics Chat 9 09-08-2010 12:53 PM
Counter Circuit for model wind turbine shaft. windfarm The Projects Forum 1 08-12-2010 03:47 PM
wind turbine load control circuit polter The Projects Forum 4 02-26-2010 03:43 PM
24V regulated DC power supply output 47V eman General Electronics Chat 7 08-09-2006 11:43 AM
Measuring DC output jvanland General Electronics Chat 3 02-21-2004 10:52 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
