All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-27-2011, 01:21 PM
and1_hotsauce and1_hotsauce is offline
Junior Member
Default how to connect Pot in series with resistor
I'm trying to connect the circuit pictured to the left. Both resistors are going into pin 2. How would I be able to make 5k a variable resistor?
I have connected leg 3 of POT to resistor. But would that not also make the 10k a variable resistor??
  #2
Old 04-27-2011, 01:37 PM
DerStrom8's Avatar
DerStrom8 DerStrom8 is offline
Default
Quote:
No, if you connect it the way it is drawn, the 5K pot will work independently of the 10K fixed resistor. It appears that you have it connected correctly.
Der Strom
  #3
Old 04-27-2011, 01:39 PM
Adjuster's Avatar
Adjuster Adjuster is offline
Default
Your sketch on the left side of the picture shows one fixed resistor and one variable resistor connected to pin 2 of an IC. The breadboard seems to show two resistors connected to pin 2, one of which is a 5k variable, connected to another pot of unspecified value.
You then ask if connecting the pot would make another resistor variable. I would think not, although the total resistance would be variable, within a limited range. Could you explain more clearly what you are trying to do?
  #4
Old 04-27-2011, 01:58 PM
Junior Member
Default
sorry let me be a bit more specific
Assume I dont have a 30.6K and 510 ohm resistor(fig below). Instead I have a 28K and 500 ohm resistors instead. I want to connect TWO pots in series with each resistor in order to bring the value up to 30.k and 510 ohm respectively.
The dilemma is, if I connect a pot in series with R1 does it not automatically make R2 a variable resistor as well?
In the circuit above I have connecetd the pot to 30k pot to the 5k resistor FOR EXAMPLE, to bring it to 30.6 k. By twisting the knob, does it effect both resistors?
  #5
Old 04-27-2011, 02:02 PM
Junior Member
Default
Quote:
Der Strom
What you mean? Both resistors are connected to pin 2 which is aht I have drawn (ms paint). How do I connect the pot to control only one of the resistors?
  #6
Old 04-27-2011, 02:29 PM
Adjuster's Avatar
Default
If the 10kΩ is a fixed resistor, then it will not change just because another resistor connected to the same point is variable.
If the two resistors are connected in series or parallel, then the total equivalent resistance will vary, but this is not the same thing. The 10kΩ remains 10kΩ, only an equivalent resistance changes.
  #7
Old 04-27-2011, 02:36 PM
Junior Member
Default
thanks for that! So can I say now that my 5K resistor is effectively a variable resistor? Is this the proper way to connect a pot to a resistor in order to make it variable??
  #8
Old 04-27-2011, 04:01 PM
bluemarvin bluemarvin is offline
Default
The 3 pot terminals may be confusing you...you need to use only the wiper and either of the other two terminals...this will vary the resistance across those two points from 0 to 5k or whatever the pot value is. Connect one of those two points to your fixed resistor in SERIES and you will make a variable resistor ranging from the fixed value to the fixed value plus 5k. You could also connect them in parallel but that would only get you 0 to 3.33k if the fixed is 10k and the pot is 5k.
  #9
Old 04-28-2011, 12:34 AM
Junior Member
Default
thanks got it now
Tags
Related Site Pages
Section Title
Worksheet Switched capacitor circuitry
Worksheet Performance-based assessments for semiconductor circuit competencies
Worksheet AC network analysis
Worksheet Simultaneous equations for circuit analysis
Worksheet Performance-based assessments for AC circuit competencies
Worksheet Series-parallel DC circuits
Worksheet Potentiometers
Worksheet Voltage divider circuits
Worksheet Performance-based assessments for basic electricity competencies
Worksheet Series DC circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
switch help + wire help dd1313 General Electronics Chat 4 05-24-2010 10:53 PM
quick question ihaveaquestion Homework Help 4 08-19-2009 08:50 PM
a power soucre parrallel to a resitor and in series with another resistor Unregistered Feedback and Suggestions 1 02-12-2009 04:42 PM
50k pot into 10k or 100 ohm pot Overclocked2300 General Electronics Chat 2 10-27-2005 08:06 AM
Series resistor knoblame General Electronics Chat 4 05-24-2005 08:39 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
