All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-27-2007, 11:17 PM
chules chules is offline
Default Finding Inductance with Current
I have an inductor which I am trying to measure the inductance of. I don't have an inductance meter, but it seems to me that it would be possible to calculate the inductance by measuring the current through a series circuit of the inductor, a resistor, and a multimeter, connected to a 120V, 60Hz, mains supply. The DC resistance of the inductor and multimeter can be found using the multimeter. Is there a way to calculate the reactance and the inductance of the inductor using these values? If so, how? A mathematical explanation would be greatly appreciated.
Thanks,
Chules
  #2
Old 03-27-2007, 11:36 PM
Dave_ Dave_ is offline
Junior Member
Default
I dont think you could calculate it from those values, otherwise the person who built his own inductance meter would of done it that way. The site can be found here:
http://users.tpg.com.au/ldbutler/RFInducMeter.htm
So he varies a known capacitor value until there is a circuit resonance, which will enabe the person to work out what value of inductance it is.
The formula for reactance is
X = 2 * Pi * F * L
where F = frequency (Hz)
L = inductance (H)
So looking at that it seems that you must know what frequency and inductance it is for the reactance.
Hopefully that's a point in the right direction
  #3
Old 03-27-2007, 11:55 PM
Default
I was thinking about that, but I still think it might be possible to calculate the inductance with those values. Since changing the inductance/reactance of the inductor would cause a different amount of current to flow, there has to be a relationship between the two, and that relationship can probably be determined mathematically. The reactance could be calculated by other means than the formula you presented, such as by some kind of Ohm's law relations, and then that formula could be used in reverse to calculate the inductance. As far as the frequency, I know the frequency, it's 60Hz line frequency.
Thanks,
Chules
  #4
Old 03-28-2007, 12:32 AM
beenthere's Avatar
beenthere beenthere is offline
Default
For smallish values of L, 60 Hz will not be a good frequency. For a longer life, fooling with live conductors is not advised.
The meter and resistor are ok, but using something like a signal generator for the AC source will let you get more accurate and safer results. When the drop across the inductor and the resistor is equal, then Xl equals the resistor.
  #5
Old 03-28-2007, 12:38 AM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
Here's a DIY inductance meter adaptor for any voltmeter: http://www.armory.com/~rstevew/Public/TestEquip/IndMeterAdapter.htm
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #6
Old 03-28-2007, 01:51 AM
Default
I can't really build an inductance meter because I don't have the parts for one, and the measurements I do have for the current on the inductors in question were somewhat difficult to get due to my access to the inductors.
As far as using mains current, I think that in this instance it is the best way to go because the inductors in question are Microwave Oven Transformers with shorted secondary coils. The eventual plan is to use them as ballasts in a Tesla Coil, but I need to know the inductance/reactance first. Since these are designed to operate on 60Hz, at mains voltage, and have sufficient inductance to limit current to slightly over 15A without a resistor, I think mains current is the best choice here. (I only have 15A circuit breakers here so I can't just measure current through the inductor itself).
  #7
Old 03-28-2007, 02:24 AM
Super Moderator
Default
I'm sorry, but if you don't know the formulas for Ohm's Law and inductive reactance, then you really should not be attempting a Tesla coil at this time. Thread closed.
__________________
- Michael Faraday
  #8
Old 03-28-2007, 05:14 AM
Super Moderator
Default
PM recieved. I apologise for having misunderstood the situation. Thread re-opened.
Z = Sqrt(R^2 + XL^2)
Kirchoff's current law applies, therefore Esource = Sqrt(ER^2 + EL^2)
__________________
- Michael Faraday
Tags
Related Site Pages
Section Title
Video Lecture Capacitors (Part 2) - Current Flow in a Capacitive Circuit - Inductors,Capacitors,Transformers
Video Lecture Inductors (Part 2) - Types and Applications - Inductors,Capacitors,Transformers
Worksheet Performance-based assessments for AC circuit competencies
Worksheet Passive filter circuits
Worksheet Resonance
Worksheet Series and parallel AC circuits
Worksheet Impedance
Worksheet Inductive reactance
Video Lecture Inductors (Part 1) - Inductors,Capacitors,Transformers
Textbook AC inductor circuits : Reactance And Impedance -- Inductive
Similar Threads
Thread Thread Starter Forum Replies Last Post
High Voltage Low Current SoundGuy General Electronics Chat 12 11-05-2009 12:21 PM
voltage dividers pilotnmech Homework Help 16 01-14-2008 02:30 PM
fields alphaone Physics 4 12-23-2005 06:03 PM
The "real" direction of electric current wbeaty General Electronics Chat 3 07-17-2005 03:23 PM
Measuring current using inductance coil Parthasarathy General Electronics Chat 2 02-17-2004 01:25 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
