All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-26-2011, 03:17 AM
fran1942 fran1942 is offline
Member
Default basic loop analysis of circuits
Hello, I am trying to learn how to analyse circuits using loop analysis.
I have this circuit (attached file) and I want to calculate the three currents I1, I2 and I3. I think the procedure is as follows.
- Divide into three mesh loops (I have labelled them 1, 2, 3)
- Sum the voltages around each loop and equate to zero:
eg.
Loop 1: 7 - I1 + 2(I2) = 0
Loop 2: 5 - 9(I3) - 2(I2) = 0
Loop 3: 5 - 3(I3) = 0
- solve the simultaneous equations to obtain values for the currents.
The problem is, I am unsure if have calculated the three loop equations correctly.
Can someone please tell me if I am going wrong here ?
Thanks kindly for any help.
  #2
Old 04-26-2011, 04:51 AM
mjhilger mjhilger is offline
Default
You have the right idea, but the loop equations are wrong as the loop and the labeled I's are not the same. Draw a clockwise circle around your 1 & 2. Loop 3 (also clockwise) is a given as the only voltage that can exists at its node is the 5 volts; and loop 3 is isolated as to not contribute to either loop 1 or 2. So I'll show the loop currents as lower case i's
loop 1: 7 = 1(i1) + 2(i1 - i2)
loop 2: 5 = 9(i2) + 2(i2 - i1)
loop 3: -5 = 3(i3)
But note that these i's are not the same as the ones listed on your picture.
Also note, the node at top of the 2 ohm resistes is: sumation of currents is 0 I1 + I2 = I3 (these I's are the one's labeled on your schematic).
Hope that helps
The Following User Says Thank You to mjhilger For This Useful Post:
fran1942 (04-27-2011)
  #3
Old 04-26-2011, 11:03 PM
Member
Default
Hello, thank you kindly for helping.
I have attached another picture of two circuits including the one you advised on.
I have included loop formulas as I understand them, however I dont think I am quite correct.
Can you please advise if and where I am going wrong ?
Again, thank you very much.
  #4
Old 04-27-2011, 04:17 AM
t_n_k t_n_k is offline
Default
Check out the attachment.
Only one of your loop equations was correct.
I suggest placing polarity signs on the resistors and voltage sources based on indicated current flows (for the resistors) - the voltage sources have fixed polarity. As you go around the loop (you seem to use anti-clockwise convention - which is fine) look at the sign you encounter at each successive loop element, whether it be a resistor or voltage source - that sign then becomes the sign [+ or -] for the voltage potential difference you assign to that part of the loop. Once you complete the full loop traversal you then place the "=0" part to complete the equation.
Note that this particular approach for your examples requires you to formulate another equation which relates the individual currents assigned in the various branches - this is based on Kirchoff's current rule. It happens to work out that in both examples I1+I2=I3
You'll also note in the second example the current in the 3Ω across the 5V source is immediately known from I=V/R. Also note that I3 "splits" into two parts as it passes through the 5V source in parallel with the 3Ω. The current in the 3Ω will have no bearing on what happens in the rest of the circuit - the 5V source fixes the potential difference for that part of the circuit.
The Following User Says Thank You to t_n_k For This Useful Post:
  #5
Old 04-27-2011, 04:19 AM
Default
Woops! - Here's the attachment ....
  #6
Old 04-27-2011, 05:31 AM
Default
t_n_k, the loop equations he has written in the circuits is correct, however he is mixing the loop mesh currents from my equations (lower case i's) with the upper case I's illustrated in the schematic. At least in the second schematic. By moving the equation totally to the left side of the equal sign, it appears that the loop was set up counter clock wise.
With the equations I listed in my post you can completely solve the problem without the KCL node. However, to relate the uppercase I's to the loop i's, it is necessary to use this fact. I should have posted the relationship in my first post
So:
I1 = i1
I2 = i2 - i1
I3 = i2
Took me a few seconds to identify what was happening. But confusing the loop currents where KVL is applied to 0 the loop with the listed currents on the diagram is the main problem.
You should see that the answer is the same between both my and t_n_k's responses. Just make sure you know the difference between the loop currents (lower case i's) and the currents identified on the schematic (upper case I's).
I must say that the labeling of the I3 on the diagram (second circuit) is contributing to the confusion. That is a very poorly designed problem, in my humble opinion.
  #7
Old 04-27-2011, 06:27 AM
Default
The second circuit equations look OK - if we are referring to mesh currents - rather than the designated currents on the schematic.
The top circuit equations are still incorrect.... both of them.
Let's take the first circuit with the two loops. I1 will be the clockwise loop current in the left-hand mesh and I2 the clockwise current in the right-hand mesh. Assume I1 & I2 aren't the same as those shown on the original diagram.
The two equations would be
-11+5*I1-I2=0
or (with sign reversal throughout)
11-5*I1+I2=0
8-I1+6*I2=0
or
-8+I1-6*I2=0
To fran1942:
You would do well to clearly show the intended current paths and directions on your diagrams. There is likely to be less confusion as has arisen here. Several members will often respond to the same post. So clearly stating your problem & solution is important to avoid this confusion.
  #8
Old 04-28-2011, 12:57 AM
Member
Default
thanks guys for your great help. I understand what you have discussed.
However, I have one more, more complicated circuit that I cannot figure out.
If I can just see how you derive the formulas for this one, then I will be totally confident.
I have attached the picture of the circuit. If you have time, it would be much appreciated. I think there will be 5 loops comprising I1, I2, I3, I4 and I5 ?
nb. t_n_k - the way you solved the first set of circuits that I posted, is how we interpret them. I followed that method well.
  #9
Old 04-28-2011, 01:40 AM
Default
This problem has 3 different resistor branches where the current is solely determined by a single voltage source.
In such cases you can work out the current in those branches and then remove them from the circuit to analyze for the current in other branches which are dependent on more than one source. This allows a simplified analysis - notionally from 5 loop currents to 2 loop currents in this case.
I've attempted to illustrate this in the attachment.
NB If you use this method - you must remember that if required to calculate the total current drawn from the various voltage sources, you would then need to add the currents (magnitude & direction) flowing in the branches removed in the circuit reduction applied. That's only important if you were asked to calculate the current drawn from the sources.
Tags
Related Site Pages
Section Title
Textbook Millman's Theorem revisited : Dc Network Analysis
Worksheet DC mesh current analysis
Worksheet DC branch current analysis
Worksheet Component modeling
Video Lecture Parallel Circuits - Circuits
Textbook Current divider : Dc Circuits
Textbook Millman's Theorem : Dc Network Analysis
Textbook Mesh current method : Dc Network Analysis
Textbook Branch current method : Dc Network Analysis
Textbook Simple parallel circuits : Series And Parallel Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need help with Loop Analysis codehunter447 Homework Help 0 11-26-2009 11:33 PM
Multisim Error zaidqais Electronics Resources 0 08-23-2009 05:54 PM
From Nothing to Designing Circuits, Help Please? digitalmind General Electronics Chat 23 03-10-2009 02:07 AM
Delay loop problem ShaunManners Embedded Systems and Microcontrollers 12 04-21-2008 09:30 AM
Digital Circuits menewbie Homework Help 10 03-07-2006 11:20 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
