Is it really that important to remove the drop down? It doesn't prevent you from typing the whole command. If anything, the reappearance of the drop-down should serve to help you memorise the commands.I just want to memorize all that command because everytime I type a letter all the command that i type before appear. I just want to memorize it so that i can use that in other computer![]()
Well, we are talking about the drop-down on the run dialog invoked from the Start - Run right? If so, it should work. I've been using that for a long time. It is not really helpful saying it didn't work, without elaborating more. Did you find the Clear List button or not?Hi n9352527
I follow your procedure... Its still no effect. Is there other way?
Allied
I can confirm this method works.Right-click on the Taskbar, select menu item Properties from the pop-up menu. Select the Start Menu tab (2nd tab) from the pop-up window. Click the Customize button on the right of the Start Menu radio button. Select the Advanced tab (2nd tab) from the pop-up window. Click the Clear List button on the bottom right (Recent Documents group panel).
Hi n9352527Well, we are talking about the drop-down on the run dialog invoked from the Start - Run right? If so, it should work. I've been using that for a long time. It is not really helpful saying it didn't work, without elaborating more. Did you find the Clear List button or not?
| Thread starter | Similar threads | Forum | Replies | Date |
Is windows slow or acting weird? | Off-Topic | 2 | |
FT232HL chip not recognised by Windows PC | Microcontrollers | 12 | |
Privacy and security tips for windows android and ios | Off-Topic | 0 | |
| C | Circuitry for Ferrari Power Windows | General Electronics Chat | 4 | |
| S | Slowing the motor speed for power windows. | General Electronics Chat | 14 |
