All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-23-2011, 08:23 AM
washer washer is offline
Junior Member
Question Solid State Latching Relays
Hey all,
It has been a while since I've posted here but I haven't seen this in the forums yet.
I'm working on my senior design project and one part of our system involves individually controlling each plug in a standard power outlet (120VAC 20A). We were initially looking at a SPST electromechanical or solid state relay, leaning towards solid state if we could find one rated at the right amperage for the right price. After a few hours on Digikey, I'm guessing the industry standard is 16A and we should just say our project is rated at 15A. Is that what most products are rated at? I haven't been able to see anything mentioned on things like surge protectors.
Since the goal of our main project is to encourage energy efficiency, we are trying to be as low-power as possible. We think a latching relay would be the best way to go so you aren't burning power in either state. Problem is, I haven't been able to find any off the shelf latching relays rated for 120VAC and at least 16A.
I've been looking around at some circuits and thinking we may want to make our own discrete latching solid state relay. I think I have a good grasp on how a non-latching ssr circuit works, but I'm still a little confused about how we would implement a latching one. We hope to switch 120VAC at 20V with as little power possible from the controller. We have a few optocouplers on hand, and are thinking about picking up some of these SCRs and will be using an 8051 as our controller.
Do you think a latching solid state relay is the right solution? And could you help explain how to implement the latching circuit or point me to a good reference? Also, I may just not be talking nice to Digikey today and there really is an off the shelf solution that fits our bill perfectly.
We would greatly appreciate any help! We are all a tad bit embarrassed at how rusty we have gotten since our intro circuits classes...
Thanks a ton,
washer
  #2
Old 04-23-2011, 11:35 AM
Adjuster's Avatar
Adjuster Adjuster is offline
Default
Personally I would not recommend a latching relay in such an application, even if you can find one. A normally-open type may be considered more fail-safe, unless you are considering appliances like freezers where it is important to avoid loss of supply (such things might anyway be better not connected to your system).
Perhaps more importantly, non-latching also reduces the possibility of the relay state getting out of step with the controller requirement, for example due to a glitch caused by a momentary power outage.
The power required to hold in a solid-state relay is likely to be of the order of 100mW, which may be pretty insignificant in comparison with the power consumed by the mains devices being controlled. Note that at full 20A load the SSR switch will likely dissipate about 30Watts, which is a bit more serious.
There seem to be plenty of parts out there rated at 25A or more, but maybe your budget will not allow you to buy them. Here is an example:
http://www.crydom.com/en/Products/Catalog/s_1_120.pdf
http://search.digikey.com/scripts/Dk...name=CC1002-ND
  #3
Old 04-23-2011, 11:59 AM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
Most SSR (Solid State Relays) are simple. There is a LED circuit that can take a wide range of input voltages on the input, and a optically triggered TRIAC on the other side. I would not mess with this simplicity, instead using external circuitry to create effect you need. I am a fan of SSRs, their simplicity makes them relatively fool proof.
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
  #4
Old 04-23-2011, 01:38 PM
ifixit's Avatar
ifixit ifixit is offline
Default
Hi washer,
Since you want to consume no power in either the on or off state then a solid-state solution is not possible. Refer to Adjuster's post.
Google: latching relay mechanical
Potter & brumfield have some relays that might work for you. There are two basic types, one coil that you pulse for a brief period, and one that has two coils (one for each state).
Regards,
Ifixit
__________________
"Learn the rules well, so that you'll know how to break them wisely."
“The quality of an answer is directly proportional to the quality of the question.”
  #5
Old 04-23-2011, 06:27 PM
tracecom's Avatar
tracecom tracecom is offline
Default
Quote:
Any relay can be made to latch through its own contacts, however it does draw power when it is latched. Google latching relay schematic and look at the images.
  #6
Old 04-23-2011, 06:51 PM
Junior Member
Default
Thanks for the feedback guys. I guess I didn't really think through how a solid state relay could be bistable without using any power if the LED needs to be on in the closed state.
I saw some of those Crydom relays on Digikey but we would really like to be able to build each outlet for under $50, which would be difficult if each one included 2 $30 relays.
Our other constraint is size. We may not get past the breadboard for senior design, but the idea is to eventually get this small enough to embed inside an outlet box. With that restriction, I'm leaning towards the discrete parts or a solid state this one from Sharp.
Are latching mechanical relays also always pulling power in one state? So the only difference in having it latching/bistable is that your control only needs to worry about it on the changing edges, right?
  #7
Old 04-23-2011, 07:12 PM
beenthere's Avatar
beenthere beenthere is offline
Default
Not if it's mechanical latching. See the data sheets for the S89 & 90R relays - http://relays.tycoelectronics.com/pnb.asp
__________________
First comes the hardware, then the software.
  #8
Old 04-23-2011, 07:18 PM
Adjuster's Avatar
Default
Latching relays really do physically latch, in some cases due to the action of an internal permanent magnet. The drive requirement is for a pulse lasting a certain minimum time to effect a change of state. No power is required to maintain either state once it has been set up.
Typically there are two coils: one to latch the relay, and the other to reset it. Some rarer designs may use a single coil requiring to be energised with current in one direction to latch, and in the opposite direction to reset. You would need to arrange your controller to generate the required drive pulses, and with the usual two coil arrangement this would include barring driving the two coils simultaneously.
Frankly I would not recommend making your own mains switch circuit from scratch. This is risky territory, and the safety policy on this forum means that you are unlikely to be given any advice about that. Furthermore, the design of a good safe switch is not a trivial task. If you are going to build this in any practical form, use a commercial part for the switch, and accept that you may not be able to build a full-scale 20A design if you cannot afford more highly rated devices.
  #9
Old 04-23-2011, 10:09 PM
tracecom's Avatar
Default
Quote:
I was describing a relay that is latched through its own contacts. In such an arrangement, the only way to release the relay is to interrupt the power to the coil.
Tags
Related Site Pages
Section Title
Worksheet Latch circuits
Textbook Switch types : Switches
Textbook Monostable multivibrators : Multivibrators
Textbook Digital logic with feedback : Multivibrators
Textbook The S-R latch : Multivibrators
Textbook Fail-safe design : Ladder Logic
Textbook Motor control circuits : Ladder Logic
Textbook Solid-state relays : Electromechanical Relays
Textbook Relay construction : Electromechanical Relays
Similar Threads
Thread Thread Starter Forum Replies Last Post
Submission: Sequential Circuits Georacer Feedback and Suggestions 17 10-31-2010 04:07 AM
Need help with solid state relays vijaybala85 General Electronics Chat 3 08-28-2010 12:27 AM
Pulse Input Adapter Attached to Solid State Pulser jnbfive General Electronics Chat 1 08-19-2010 03:46 AM
Solid State Relay? Macabra The Projects Forum 14 01-22-2009 03:12 PM
Need cheap solid state relays or alternative device Engineer-it-all The Projects Forum 12 09-25-2008 06:24 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
