All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-23-2011, 08:11 AM
sarjan88 sarjan88 is offline
Default band reject filter design
Design a circuit using op-amp that will reject the 60kHz power line noise and also reject high signal frequency above 800Khz. The stop-band width around the 60kHz centre frequency is 10kHz. Use a cascade of 1st order high pass and 1st order low pass filter to implement this circuit. The voltage gain at passband frequencies is 10.
As mentioned in the title, can sum1 tell me this should be a band reject or band pass filter?
i try to construct a band reject filter but the result seem like not correct.
here is my circuit using multisim
http://i325.photobucket.com/albums/k...23/circuit.jpg
here is the result using AC analysis in decibel
http://i325.photobucket.com/albums/k...123/result.jpg
bode plot
can sum1 help me out of this?
thanks
  #2
Old 04-23-2011, 03:18 PM
beenthere's Avatar
beenthere beenthere is offline
Default
What part of the world do you live in? I thought that power line frequencies were either 50 Hz or 60 Hz.
__________________
First comes the hardware, then the software.
  #3
Old 04-23-2011, 03:51 PM
Audioguru Audioguru is offline
Banned
Default
Your V3 battery is only 0V.
All opamps are biased at 0V and with the single positive supply they become rectifiers.
With your single +10V supply all opamps should be biased at +5V, not at 0V. Or use a double-polarity supply.
Tags
Related Site Pages
Section Title
Worksheet Performance-based assessments for analog integrated circuit competencies
Worksheet Active filters
Worksheet Passive filter circuits
Worksheet Mixed-frequency signals
Textbook Resonant filters : Filters
Textbook Band-stop filters : Filters
Textbook Band-pass filters : Filters
Video Lecture Op Amp Applications - Band-Pass & Band-Stop Filters - Op Amps and Op Amp Circuits
Video Lecture Op Amp Applications - Active Filters - Op Amps and Op Amp Circuits
Textbook Low-pass filters : Filters
Similar Threads
Thread Thread Starter Forum Replies Last Post
LTC1562-2/LC filter Design Help jhk3h2 The Projects Forum 0 10-08-2010 06:52 PM
-Filter Design project- DSP (((Help))) DSP student Homework Help 2 12-28-2009 05:59 PM
E-book Help LC filter design feilip General Electronics Chat 2 12-23-2009 03:08 PM
Design signal in Matlab ethan007 Programmer's Corner 2 05-12-2009 02:50 PM
Filter Design low pass passive filter. saint_jay77 General Electronics Chat 1 08-03-2007 07:37 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
