All About Circuits Forum
Go Back   All About Circuits Forum > Software, Microcomputing, and Communications Forums > Programmer's Corner
Notices
Programmer's Corner Discussion forum for all aspects of programming and software engineering. Any software programming language welcome: C, C++, C#, Fortran, Java, Matlab, etc.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-18-2011, 03:41 PM
RG23 RG23 is offline
Default Hex to BCD conversion routine
Does anyone have an idea about Hex to BCD conversion routine using pic?
Please let me know
  #2
Old 04-18-2011, 05:55 PM
Default
Is there any subroutine available for converting hex to bcd?????
  #3
Old 04-18-2011, 06:51 PM
DumboFixer DumboFixer is offline
Default
What language are you using ?
Have you tried Google or Bing ?
Have you had a go yourself ?
  #4
Old 04-18-2011, 06:54 PM
Default
i am using assembly language in pic
I tried google but didn't get any satisfying results
If you have any idea please let me know
  #5
Old 04-18-2011, 07:27 PM
Markd77's Avatar
Markd77 Markd77 is online now
Default
By hex do you mean a natural number stored in a register (or registers)? If so this should help. If you are not worried about memory, the unpacked BCD is easier to work with.
http://www.piclist.com/techref/micro...adix/index.htm
  #6
Old 04-18-2011, 07:35 PM
Default
Unpacked BCD to 16 bit binary conversion by Nikolai Golovchenko
but using the above I would get binary result
i am getting the correct frequency but its in hex format
so i first need to convert hex to bcd
i have bcd to ascii subroutine to display on LCD
  #7
Old 04-18-2011, 07:37 PM
Default
At present when i divide 0x64 (decimal 100) by 0x21 (decimal 33)
I get 3.07 on LCD which is hex but i want to see 3.03 (decimal)
  #8
Old 04-18-2011, 08:16 PM
Default
i have still not figured it out
any help would be appreciated
  #9
Old 04-19-2011, 02:58 PM
Default
Which unpacked bcd routine are you referring to?
  #10
Old 04-19-2011, 05:11 PM
Markd77's Avatar
Default
I meant one of the binary to unpacked BCD links.
Unpacked stores each BCD digit in a byte, but packed stores 2 BCD digits in each byte.
eg. 93 is stored as b'10010011' in packed but as b'00001001' and b'00000011' in unpacked.
I think we need to see your code to be more help.
Tags
Related Site Pages
Section Title
Worksheet Microcontroller principles
Worksheet Digital codes
Worksheet Numeration systems
Similar Threads
Thread Thread Starter Forum Replies Last Post
Compilation Error for Microchip IDE , C18 arikiev Embedded Systems and Microcontrollers 4 09-20-2010 08:32 PM
BCD to HEX in assembly Jefecito20 Programmer's Corner 1 05-06-2010 03:56 AM
PIC16f877- 16 bit hex to bcd converter amitesh Embedded Systems and Microcontrollers 1 03-01-2009 02:02 PM
8086 Microprocessor using Debug (hex to bin conversion) Reshma Programmer's Corner 6 12-19-2007 01:16 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
