I have a ckt with an LM339, output voltage is 6v. Rail voltage is 8V. I need to control a 12V relay which switched at 8V. I am using a darlington transistor and i tried to follow what SGTWOOKIE mentioned in this thread.
http://forum.allaboutcircuits.com/showthread.php?t=11450
It doesnt work for some reason. Is it necessary that I use a diode. Will the ckt work without one.
Thanks for the help.
