Just a simple question concerning center tap transformers and current, to see if I understand it correctly. I've read the e-book, but I'm still not 100% clear.
Let's say I have a 48VA 24VCT transformer. If the secondary is wired to produce 24 volts then it could produce 2A of current (ignoring de-rating for simplicity sake).
Now, if you wire from one end of the secondary to the center tap, producing 12 volts, would you be able to draw a (theoretical) 4A of current from it?
And then if all three taps are wired to make a +/-12V dual power supply, can each "side" of the supply only draw up to 1A?
Thanks for your help!
- Steve
- Steve
