All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-11-2011, 11:36 PM
Prototape Prototape is offline
Junior Member
Default 3 bit synchronous counter
So I have to analyze a 3 bit synchronous counter much like this:
From that I'm supposed to supply:
1. A state table
2. A state diagram
3. A timing diagram.
I know what a state table, state diagram, and timing diagram are so that base is covered, but what my question is... what the <snip>?
I read the chapter in my book and it was no help. I went to the internet and found this video:
http://www.youtube.com/watch?v=aommE...feature=relmfu
But it really only covers 2 bit, not 3 bit. When he does do 3 bit he does something covering only even numbers.. I don't know. It helped a little bit, but not so much. Especially since he did the process backwards to create a synchronous counter, rather than what I need which is finding the specifications behind the diagram.
What I do understand:
The AND gates make it so the inputs must be logic HIGH in order to press on. Other than that, this whole thing has me stumped.
I would appreciate any help. Whether it be someone explaining it or just linking me to some material. I'll actually read it too
  #2
Old 04-12-2011, 01:22 AM
Georacer's Avatar
Georacer Georacer is offline
Super Moderator
Default
First, check here: http://www.allaboutcircuits.com/vol_4/chpt_11/3.html
It might not add much, but anything helps.
Can you post any of your efforts to solve the problem? Try to complete the state diagram at least. We require you to do a bit of effort before receiving help here.
But 3 bits aren't that different from 2bits really...
__________________
I am a prisoner of high standards and low social skills
____________________________________
I wish I was the best at what I would do, and what I would do wouldn't be pretty.
  #3
Old 04-13-2011, 01:27 AM
Junior Member
Default
I checked that out but it didn't help much :/
I wasn't necessarily asking people to finish my homework for me, I just need something to start me off, I come here as a last resort because there's more people who need help.
My attempt at a state diagram consisted of J and K 0-2 to be all logic HIGHs. From what I can tell, the diagram says that J0 and K0 are 1 as per the 1 behind them. From there, I suspected J1 and K1 must be high, referring to the AND gate which states that all inputs must be high to give output high. J2 and K2 must also be high in order to keep the sequence going, but K would have to be a 0 to repeat, correct?
I have no idea if that's right, but it's just the hunch I got. This whole thing pretty much confused me, though.
  #4
Old 04-13-2011, 12:25 PM
Georacer's Avatar
Super Moderator
Default
Ok, you can start by the state diagram. At first assume that all 3 FFs have 0 internal state. That means that you are at the 000 state count. Check what the output will be.
Now notice that the J and K inputs are either constant (J0, K0) or a function of the current outputs. That lets you build the inputs for the next cycle, and eventually build the whole diagram.
For example, after starting from 000, you have:
J0=1, K0=1
J1=(1 AND 0)=0, K1=0
J2=(0 AND 0)=0, K2=0
Therefore the next state will be 100.
Continue this way to construct the whole state diagram (which of course you know it's a simple 3-bit count).
Once you have your diagram, the rest is easy. Check here http://www.allaboutcircuits.com/vol_4/chpt_11/5.html for a tutorial.
I think what you ask is the first table of the tutorial.
Is that clear?
__________________
  #5
Old 04-13-2011, 08:23 PM
Junior Member
Default
Aaaah. That cleared things up quite a bit, thank you!
Tags
Related Site Pages
Section Title
Worksheet Counters
Worksheet Flip-flop circuits
Worksheet AC network analysis
Video Lecture Counters - Digital
Textbook Ring counters : Shift Registers
Textbook Finite State Machines : Sequential Circuits Counters
Textbook Asynchronous counters : Sequential Circuits Counters
Textbook Synchronous counters : Sequential Circuits Counters
Textbook The J-K flip-flop : Multivibrators
Textbook Don't care cells in the Karnaugh map : Karnaugh Mapping
Similar Threads
Thread Thread Starter Forum Replies Last Post
3 bit Synchronous Up Down Counter that automatically counts up and down rkobasketball Homework Help 6 03-14-2010 03:46 AM
2 bit synchronous up counter WizzleFiend3 Homework Help 3 11-19-2009 06:34 PM
Synchronous 2bit counter using DFF baaf Homework Help 1 04-07-2009 12:23 AM
3 Bit Counter J-K FF's djplayer Homework Help 1 12-02-2008 09:31 PM
synchronous counter samrat Homework Help 3 04-03-2008 09:30 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
