Alright, I recently got it running, so now I'm going to try to turn the old TI model 924 Video Display Terminal I got into an oscilloscope so I can probe things over 20V without fear of ruining my small digital scope.
From what I've read, the easiest thing to do is to take the vertical deflection signal (lower frequency) and attach it to the horizontal deflection coils, and then do what you wish with the vertical deflection coils.
This also requires that the entire vertical portion of the screen be covered, and currently all I get is the message "Keyboard Failure Detected"
So would it be easier to input a fake keyboard signal (I detected 2 pins that aren't either connected directly to +15V or Ground), or just build new horizontal sweep circuitry.
I don't expect to be analyzing waveforms, just seeing how steady a voltage level is or what kind of waveform there is or if there even is one. But I would still like to be able to go from approximately 1Hz-50kHz (probably a little optimistic).
Here's links to the pics
http://forum.allaboutcircuits.com/attachment.php?attachmentid=29292&d=1302059545
http://forum.allaboutcircuits.com/attachment.php?attachmentid=29293&d=1302059545
http://forum.allaboutcircuits.com/attachment.php?attachmentid=29323&d=1302117364
Thanks in advance, any input is appreciated!
[EDIT]
I hope this isn't considered too dangerous and needs to be locked, but if it is I understand.
[EDIT]
