Ok, I get the mid point tapped neutral Δ but the corner grounded Δis hard to understand attaching a corner of phase or a line? to ground.
I can't see how using my picture you can intentionally ground any secondary phase line or corner???
Can someone point me to a schematic similar to this one that shows how the corner is connected to ground.
I picture a single phase transformer as an electrically/magnetically powered stationary generator. Not sure I have it 100% but think I understand how you can attach a 1 phase control transformer to 3phase Y power to make 1 phase control power. Then ground at secondary side if phased appropiately ie attach L1 primary to H1 and L2 or L3 to H2 and then X2 becomes the return and can be grounded for secondary (and use primary neutral and or ground but this does not totally isolate the circuits).
Or I think you can use X1 as a grounded return if it will be a truely seperately derived system and will not share Neutral/Ground connection with primary side but there will be a inverse in wave form phase from primary to secondary.
So having typed that..... So do you just do it similarly and maybe like this
Y-Δ(corner grounded)
Transformer1
A-H1, B-H2 then X2-ground X1 - becomes a phase seconday
Transformer 2
B-H1, C-H2 then X2 ground X1 becomes b phase seconday
Transformer 3
C-H1, A-H2 then X1 to ground and X2 becomes c phase seconday
And or how would you configure a Δ-Δ corner grounded bank?
Transformer1
Transformer 2
Transformer 3
