dual axis solar tracker
ERAVASHISTHA
Joined Apr 5, 2011
hi,
i have decided to make a project on dual axis solar tracker but my group has decided not to use LDRs or any type of sensors. instead we have decided to make it time controlled using a 555 timer and microcontroller. can any one please help me out with the circuit diagram for the same because i have zero clue about electronics....:p
mbxs3
Joined Oct 14, 2009
170
Hi. I am curious as to why your group decided to not use sensors. I would think sensors would provide the capability of collecting the most sunlight at all times. Is it a project stipulation or is the 555 and microcontroller supposed to be more accurate? Just wondering, I want to build a similar project in the near future so I am gathering all the information I can.
hobbyist
Joined Aug 10, 2008
892
With no sensors, then your not tracking solar light, per say, but rather you need to program the microcontroller to track the suns path across the sky.
Such as a telescope does to track the stars. (Atizmuth tracking) I think.
mbxs3
Joined Oct 14, 2009
170
I think one issue you would run into using a timing system would be if you plan on using the system in different locations. You would have to reprogram the system to account for geographical changes.
wayneh
Joined Sep 9, 2010
18,127
Telescope-type tracking is indeed what you need. It's just a clock with your panels as the hour hand. You need 360° of rotation every 24hrs. Rotation is about an axis pointed at the north star, as appropriate for your latitude.
Of course for telescopes and solar panels you don't usually need more than 180° of rotation, generally much less. But you need some way to reset the position until the sun comes back around in the morning.
If you want to adjust for seasonal variation in sun position, you need adjustment around another axis perpendicular to the main (daily). Without sensors, I think you'd have to adjust this one manually. Clock mechanisms have been developed for all of this, but it's complex.
