All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-22-2004, 07:21 PM
dun_noe dun_noe is offline
Default
Hi all,
I have to do laboratory report for electronics, the laboratory is about the simple BJT inverter circuit. The circuit consists of one RB = 6.8 k (base resistor), one RC = 1 k (collector resistor), and one transistor 2N2222. A 10 kHz TTL signal (from the TTL output of the Function Generator) is supplied to VIN, and the output waveform is observed on the oscilloscope. Then this experiment is repeated for RC = 10 K.
After I observed the waveforms, the switching time for circuit with RC = 1 K is less than the switching time for the circuit with RC = 10 K.
But I get stuck with this question, why the RC value affects the switching time of the output voltage, I've been searching in my textbook and also over the internet, but I still can not understand why.....
Please help me...I have to submit my report in 3 days.
Thank you very much for your help
  #2
Old 10-23-2004, 01:57 AM
beenthere's Avatar
beenthere beenthere is offline
Default
That's a wierdie, alright. I would have expected the 2222 to switch faster with the 10K collector resistor. With 6.8K in the base, the transistor is nowhere near saturated. Just for giggles, drop it to 4.7K and see what happens. That won't really saturate the base either, but 4.7K seems to be the value that makes things work right.
Pure superstition? Probably, but it can't hurt.
There's another variable, too. A 2N2222 in a TO-18 can works differently from a 2N2222A in TO-92 epoxy. The TO-18 works better, for some reason.
Seriously, the transistor has to take less time going into full conduction with a 10K collector resistor than with a 1K. A smaller base resistor should speed things up, too.
__________________
First comes the hardware, then the software.
  #3
Old 10-23-2004, 08:44 PM
Default
Hi, thank you very much for your reply.
But I still confuse, I get the same results if I try to simulate my circuit using PSIPE.
Thanks....
  #4
Old 10-24-2004, 08:21 AM
bebop bebop is offline
Send a message via AIM to bebop
Default
Thanks....
I'm not that familiar with transistors, but I think your answer has to do with how fast charge carriers are moving between base and collector.
With a bigger collector resistor, will the transistor spend more time in the active region during a transition from on/off or off/on due to the speed charge carriers are limited to moving?
Just an idea. Can anyone elaborate or explain in more detail?
  #5
Old 10-27-2004, 08:33 AM
cyberhehe cyberhehe is offline
Member
Default
Hi Dun_noe,
Did you consider the capacitive effects of your scope when you do the measurements? Assuming there is indeed a capacitance around, you should consider this cap specially when doing the turn off (high to low transistion) in the output side. If we assume the capacitance will be constant, then for a 10K RC, will have definitely slower fall time, than the 1K resistor.
Now in your PSPICE, simulation, you should try to place this cap equivalent from your collector output path to Ground and do the simulation again, this way I think you may have similar results.
Cyber
  #6
Old 10-31-2004, 01:10 AM
avionicsgirl avionicsgirl is offline
Default
what configuration is this (ie where is DC ground) CE, CB, or CC
the DC bias of the circuit is coming in on the Collector because your AC signal (by the way was it square, triangle or sine - sounds like square because you say 'switching') is coming in on the Base and GND is on the Emitter.... right?
your results are most likely correct. if i could see a rough schematic of what you are doing, i could do the math.
  #7
Old 10-31-2004, 11:57 PM
Member
Default
I think most discrete (transistor) switches operate in a common Emitter configuration, whether you implement it in NPN or PNP configuration.
  #8
Old 11-24-2006, 04:59 PM
amriths04 amriths04 is offline
Default
the collector resistor rc and the stray capacitances inherently present in the transistor together give a time constant of (Rc*Cstray). thus if Rc is high, it takes a longer time, else a shorter time.
regards,
amrith.s
Tags
Related Site Pages
Section Title
Worksheet Performance-based assessments for semiconductor circuit competencies
Worksheet Junction field-effect transistors
Worksheet Bipolar junction transistors in active mode
Worksheet Bipolar junction transistor theory
Textbook Radio circuits -- INCOMPLETE : Practical Analog Semiconductor Circuits
Textbook BJT quirks : Bipolar Junction Transistors
Textbook Transistor ratings and packages : Bipolar Junction Transistors
Textbook Biasing calculations : Bipolar Junction Transistors
Textbook The cascode amplifier : Bipolar Junction Transistors
Textbook Bipolar junction transistors : Solid-state Device Theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
Simple Logic Inverter chrisw1990 The Projects Forum 28 04-18-2012 08:47 PM
BJT Biasing - Simple easy 1 minute answer! aly34 Homework Help 15 02-05-2012 06:27 AM
208/240V Low Current 3 Phase Simple Inverter Help adamj12b General Electronics Chat 0 03-23-2009 12:53 AM
AND Gate + Inverter Question??? HELP lisandro General Electronics Chat 8 07-29-2007 07:22 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
